Rhino ramps
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Yes, they are ok for oil changes...no creeper
I regret buying them. I used them twice. They slide forward when trying to roll up. Some have found ways around it. I also dont trust them. I prefer a jack and stands.
I've only heard of two sets failing. One cracked in pieces and the other bent in half. Then there's this.. http://forums.corvetteforum.com/c4-g...ino-ramps.html Whatever you decide use stands as back up and wheel wedges.
I use them for oil changes. Never had them slide forward.
I put a short 2x6 in front of each, just to get the tires to start their upward travel before getting to the ramps.
This keeps the front spoiler from hitting the ramps and pushing them forward.
I used them on my former C4 and still use them on all my cars to do whatever work I need done.Some people on here used 2x4 wood to drive over and drive onto the ramps to prevent pushing with the front spoiler.
+1, works great
Without some kind of method to hold them in place, mine always just scoot along the floor. I wouldn't buy them again because of that.
On top of that, when I do build some kind of contraption to hold them in place, the car is barely high enough to do anything to. I can do an oil change on them, but it's cramped and still sucks. It seems like the only thing they are good for is getting the car up high enough to get my floor jack underneath it.
Sometimes I back up onto them, which works much better, but for the most part I leave them in the corner.
A, Change all the universals.
B, repair the mounts for the GE Kit.
C, Lower/rebush the front and rear suspensions and change the front Stabilizer bar.
Where can I place the Jack Stands hold the car safely to accomplish these tasks?
I also use a small piece of wood to prevent them pushing out. They do have anti-skid pads but I think if your floor is too smooth, they won't work. So, no good for you ballers with marble floor garages.
I use mine front or back on rough driveway surface and they work great. I agree you cann't change tires or do brakes but that would be because the tires are what is holding the car up. lol. for most daily chores it works great, a hole lot better than the long high ramps I have to basically build to drive up on. I was able to do timing chain and oil pan with the ramps. No matter what you use it's a PITA to do much anything on or under the car (it has nothing to do with me getting older. lol. good luck and enjoy.
Woody
Woody
