1989 Charcoal Canister Purge Solenoid?
Old 06-02-2009, 04:07 PM
dry
dry's Avatar
Default 1989 Charcoal Canister Purge Solenoid?
On an 89 C4 why would charcoal canister purge solenoid be extremely hot to the touch with in a few minutes of starting the car? it actually gets to hot to touch!!
What happens if you bypass/eliminate the solenoid along with the canister, seeing as how there are know emmissions checks in my state.
Thanking you in advance!
Old 06-02-2009, 07:39 PM
dry
dry's Avatar
Old 06-02-2009, 08:28 PM
joe wilson
joe wilson's Avatar
If you take all the canister stuff off it nothing adverse will happen...The tank will just vent into the air like the old cars did. You will have to do something about that pesky "check engine" light. You had also better save the parts that you take off in case your state eventually does do the inspections. That's one reason I haven't done mine, plus the pump and catalitic converter. I figured as soon as I get them off I'd have to reinstall them.
Old 06-02-2009, 08:36 PM
Benny42
Benny42's Avatar
An '89 won't set a check engine light for a removed purge
canister. You can lose the A.I.R. system too, no codes
will set on that either. benny
dry
dry's Avatar
Thanks for the above info, but does anyone know why the 89 C4 charcoal canister purge solenoid would be extremely hot to the touch with in a few minutes of starting the car?
Also is anything special need to remove the A.I.R System?
Old 06-02-2009, 08:40 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
I wouldn't worry about the solenoid being hot. It's probably been that way for 20 years. If it bothers you, change it. No reason to bypass it unless there is a problem. It vents the fuel tank, decreases emissions and prevents gas smell from entering the passenger area. There is no performance to be gained by eliminating the setup.
Old 06-02-2009, 08:44 PM
dry
dry's Avatar
Thanks, just concerned about it being HOT and damaging something else because of an electrical problem or something. Just happened to notice this by accident after replacing the canister..........
Old 06-02-2009, 08:50 PM
joe wilson
joe wilson's Avatar
As far as I know, the only thing that would make an electrical component hot would be a short or being close to something that's hot. It would probably be hard to test for a short, so just replace it if it bothers you. If the electrical part is shorted it probably isn't working right anyway.
Old 06-02-2009, 08:53 PM
Benny42
Benny42's Avatar
I agree with 383vette. No reason to delete it if it works or is
repairable. The A.I.R. system will need an eliminator bracket
to replace the pump. My pump failed so i ditched it and removed the hoses and solenoids. benny
Old 06-02-2009, 08:56 PM
jimg's'93
jimg's'93's Avatar
Not sure if that's normal or not on your year, but a solenoid that has continual power to it will get hot to the touch. If that's the case, you've got to find out why it's being activated continually. It could also have an internal short.
Old 06-02-2009, 08:59 PM
Benny42
Benny42's Avatar
A solenoid coil will run hot in normal operation. The purge solenoid is closed when powered and unpowers/opens when
the engine warms up to normal operating temp. It isn't smoking
is it? benny
Old 06-02-2009, 09:29 PM
dry
dry's Avatar
Nope doesn't smoke, this front corner of the car has been hit lightly from behind the front bumper between wheel and bumper corner and actually smashed the canister which is why i replaced the canister. Couldn't ever see or find any damage to the solenoid or wires, guess i better look more closely............
To 1989 Charcoal Canister Purge Solenoid?
Quick Reply: 1989 Charcoal Canister Purge Solenoid?
