zz4 cam, which valve springs??
Old 06-05-2009, 03:31 PM
kitttransam
kitttransam's Avatar
Default zz4 cam, which valve springs??
Can you use stock valve springs with the ZZ4 cam? Or should I get somthing else. Need some suggestions.
Old 06-05-2009, 03:58 PM
GREGGPENN
GREGGPENN's Avatar
C4 of Year Winner (appearance mods) 2019
LT4 Hotcam springs are cheap and appropriate. If you're going to the trouble of changing cams, don't reuse old springs.
Old 06-05-2009, 04:11 PM
CAJUN C4
CAJUN C4's Avatar
That Cam,with 1:5 Rockers ,only has .474"/.501" Lift. Might be OK with stock springs but GREGGPENN is correct use the LT4 or maybe any type made with ovoid (egg shaped) wire wich I believe the LT4's are..
BTW..That's an excellent Cam for your 89' TPI. I ran that one in my 84' 355 HP.
Old 06-05-2009, 04:15 PM
kitttransam
will the lt4 springs fit on the l98 heads without any modifications?
Old 06-05-2009, 05:39 PM
Orr89rocz
Orr89rocz's Avatar
i thought hotcam springs were 1.32" diameter. I dont know what the pocket is on L98 Aluminums, but on the L98 Iron heads they wont accept springs bigger than 1.30", since stock is 1.25" i believe.
AFR sells their 1.27 springs which are awesome springs for the price and will fit stock pockets. They are alittle overkill tho for that cam. Other choices would be the 981 beehives but they are kinda pricey as well.
manley has a nice single spring I believe that is 1.25 diameter or so. 22410 i think the part number is.
Old 06-05-2009, 08:28 PM
kitttransam
oh yeah I forgot to mention it's an 89 vette. aluminum heads
Old 06-05-2009, 08:41 PM
ch@0s
ch@0s's Avatar
I have the lt4 hot springs and they fit like a glove
I bought the springs, retainers and locks and used the stock seats
My cam is a CC502 218/224 .495 .503
Old 06-05-2009, 09:11 PM
kitttransam
ok I have my mind set on the lt4 springs. Guess I need retainers and maybe keepers. Anyone know who would have the best deal on these? Or by some chance can I use my old retainers and keepers?
Old 06-05-2009, 09:59 PM
rodj
rodj's Avatar
GMPP part # 12495494. Set of 16 under $40 online
$35 at Jegs
http://www.sdpc2000.com/product/1249...ingCapKit.aspx
Retainers are # 12495492 under $20 for the lite weight LT4 ones
Lift is .474 /.510
ZZ4 /LT4 springs good for .530 ish
Old 06-05-2009, 10:30 PM
kitttransam
thanks for the help. I have one more question. Should I run 21 LBS. injectors on the l98 I'm building? Everything will basically be stock except the zz4 cam, and the flat top pistons I'm putting in my motor. Maybe add some bolt ons for the tpi system later on but this is something I need to know before I order my parts.
Old 06-05-2009, 10:38 PM
GREGGPENN
GREGGPENN's Avatar
What intake? Is the cam your only mod?
Old 06-05-2009, 10:41 PM
kitttransam
The cam is going to be the only major mod for now. I'm new at working with fuel injection. Intake is stock
Old 06-05-2009, 10:48 PM
ch@0s
ch@0s's Avatar
get an ajustable regulator and/or get better injectors. FIC is awesome get with Jon.
Old 06-06-2009, 12:35 AM
rodj
rodj's Avatar
I ran the ZZ4 cam with a well modified TPI using all stock parts inc the stock tune. Ran great ; 13.0 with A4 3.07
Later datalogging showed it could have benefited from minor adjustments to the tune ( mainly spark advance ) but otherwise it was fine.
To zz4 cam, which valve springs??
Quick Reply: zz4 cam, which valve springs??
