Location of A/C compressor relay on 91'
My 91' has the electronic air. Does anyone know where the relay for the A/C compressor is located? I searched through old threads and couldn't find anything. Thanks for the help.
AC clutch relay is under the dash and behind the inst. panel...there should be 3 relays to the left of the steering column...it's the one in the middle. I'll go with the assumption you've checked and know the AC system is fully charged.
Thanks! I did have the freon level checked. Thanks for the reminder.
