Power Steering Hard to Turn
Old 06-20-2009, 12:37 PM
CAJUN C4
CAJUN C4's Avatar
Default Power Steering Hard to Turn
My 95' Leaving this morning steering wheel hard to turn at low speeds like something grabing.Could it be the seals in the Rack and Pinion getting hard because it seems to get better when it warms up.
It has 70K Mi. on it....No Leaks
Old 06-21-2009, 02:27 PM
CAJUN C4
CAJUN C4's Avatar
No Takers ?
Old 06-21-2009, 03:09 PM
aminnich
aminnich's Avatar
Some say the is 'morning sickness' for the rack, meaning you will need a replacement rack very soon. Mine seemed to do that about two years ago. I changed the fluid and it never happened again.
Old 06-21-2009, 03:21 PM
CAJUN C4
CAJUN C4's Avatar
You Know Your Right...I sucked out a half quart from the resevoir yesterday and today it didn't do it at all..I Might do it again to be sure.I wonder if anyone makes a Conditioner for that?
Thanx for the Info
Old 06-21-2009, 03:37 PM
aminnich
aminnich's Avatar
Thanx for the Info
Yes, Lucas does and I have been running it ever since mine acted up with no problems.
Old 06-21-2009, 03:51 PM
CAJUN C4
CAJUN C4's Avatar
Great..I'll Get some
Thanx Aminnich
Old 06-21-2009, 03:56 PM
TA
TA's Avatar
Mine started getting "morning sickness" about 5 years ago. I sucked out about a 1/2 quart and added a botlle of the Lucas additive. Its been perfect ever since.
Old 06-21-2009, 03:58 PM
CAJUN C4
CAJUN C4's Avatar
Lucas Power Steering Stop Leak
Lucas Power Steering Stop Leak - LP10008
Power Steering Stop Leak is totally effective at removing hard spots and tightness in worn rack & pinions. To correct worn rack and pinions, empty the reservoir and refill it with Lucas PSSL (usually 12 oz.). Results are immediate and long lasting. 12 OZ. BOTTLE
Product# LP10008
Detailed Info Price US $8.70 Qty
Old 08-08-2009, 11:18 PM
cgl61
cgl61's Avatar
I just did the Lucas on a hard to turn and grabbing rack. Within seconds you would have thought I had a new rack. It worked wonders. I sucked out all the old fluid first. It was like dirty water with no thickness to it. Lucas is very heavy when putting in. I would try it before anything else.
Old 08-09-2009, 01:38 PM
CAJUN C4
CAJUN C4's Avatar
Mine is fine now...no problems since ...knock on wood.
Old 08-09-2009, 10:02 PM
JohnLegg
2nd Gear
JohnLegg's Avatar
Yes - Lucus worked on mine also - great product!!!
To Power Steering Hard to Turn
Quick Reply: Power Steering Hard to Turn
