(LT1 Question) Installing a new rear coolant vent tube
Old 07-29-2009, 12:13 AM
Raysur
Raysur's Avatar
Default (LT1 Question) Installing a new rear coolant vent tube
I'm cleaning up my engine bay and one item on my list is installing a newer style vent tube like this:
I'm dumping my heater core and the current vent line runs there. What years had this style?
Is it a difficult job to install a new one without pulling the motor?
Thanks,
Jeff
Old 07-29-2009, 06:35 PM
jwt1603
Support Corvetteforum!
jwt1603's Avatar
GM part number 10108636 has been discontinued. I checked several of the aftermarket places and you might be able to find one. My new engine came from Golen Engines
http://www.golenengineservice.com/index.html
According to them they never bother to replace the vent tube assembly so I didn't bother. I haven't run the car much since I put the engine in (brand new opti crapped out after 5 auto-x passes) but car ran very cool in FL heat.
Old 07-29-2009, 07:01 PM
STL94LT1
STL94LT1's Avatar
95/96 or 97 if you count the F-bodies.
Old 07-30-2009, 01:29 AM
Raysur
Raysur's Avatar
Did they plug up the vent tube assembly and not run it entirely?
Thanks for the year info. It will look so much cleaner.
Old 07-30-2009, 07:51 AM
jwt1603
jwt1603's Avatar
Yeah, plugged the outlets in both heads.
Old 07-30-2009, 10:45 AM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Well that is good news. I've always been lead to beleive that the steam tube had to be in place.
Old 07-30-2009, 03:08 PM
STL94LT1
STL94LT1's Avatar
The steam tube vents air and steam from the rear of the heads. There is also coolant flow between the heads. Remove the tube and you will possibly overheat cylinders #7 and 8.
Old 08-23-2009, 07:22 PM
Camaro4Life
Camaro4Life's Avatar
Old 08-24-2009, 09:08 AM
Strick
Strick's Avatar
I would say the engineers put them there for a reason. Can they be serviced while in the car? Good question.
Old 08-24-2009, 10:09 AM
96GS#007
96GS#007's Avatar
Received 1,745 Likes on 1,053 Posts
Yes, they can be serviced with the engine in the car. PIA, but it can be done.
Old 08-24-2009, 01:19 PM
JAKE
JAKE's Avatar
Here;s my tale of woe: When my son;t 96 LT1 was removed for a heads and cam changed, I re-installed the vent tube but DIDN'T change the washers. BIG MISTAKE.
After re-installing the engine and firing it, the passenger side washer developed a coolant leak. I tracked down two replacement washers and unscrewing the passenger side bolt wasn't a problem : BUT STARTING IT AGAIN WAS A PURE NIGHTMARE!
I took a day and a half, maybe 10 hours over-all to just get the bolt to start. It tooke me and an engine savy neighbor to finally get it started.
Now remember, that was only ONE BOLT, NOT BOTH OF THEM. Saying it was a PIA is putting it very mildly.
How hard the driver's side would be, I can't say. I'm just happy I didn't have to deal with that one too.
Also, my recommendation: DO NOT delete that vent tube. You'd be asking for trouble down the road.
Jake
West Point ROCKS! Nation's Top College per Forbes Magazine!
Old 10-25-2011, 11:54 PM
brioneschevybelair
brioneschevybelair's Avatar
Default Lt 1 vent tube bolts
Jake
HELP
anybody I am trying to replace the head gaskets and the vent tube must come off what size wrench do you need it not 5/8 and not a 15 metric ????
Old 10-26-2011, 12:00 AM
TRACKMAN2
TRACKMAN2's Avatar
you can dich the metal crossover..i use 1/4 npt fittings and a regular 3/8 hose... go an and braid for style points
Old 10-26-2011, 09:54 AM
jaa1992
jaa1992's Avatar
St. Jude Donor '12
Thank you for bringing the tech to this!
Now I can get rid of that tube that is getting to the point where its gonna leak the next time I pull it!
Old 10-26-2011, 11:12 AM
brioneschevybelair
Thank s for your Help but does but does any one know what size wrench to use to remove the stock vent tube bolts 15metric seem to big a 14 too small a 5/8 too big a 9/16 too small ?? I didnt want to destory it thank again it 94 LT1
Old 10-26-2011, 03:34 PM
jaa1992
jaa1992's Avatar
St. Jude Donor '12
I do remember the bolt heads being a little funky. The last time I Pulled the heads with it connected and then was able to get the wrench on correctly. IIRC it was a 14 but it only fit one way.
Old 10-26-2011, 04:01 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Ive done it twice with the engine in the Vette. A 15mm and torque to 30 lb-ft
If that tubing is no longer available try a junk yard or use your imagination. Cooling system hoses, two threaded 90* elbows and a "T" connector will get the job done.
To (LT1 Question) Installing a new rear coolant vent tube
Old 10-26-2011, 05:17 PM
brioneschevybelair
I got em off it was 15 metric a wrench wouldn't work so I used 15 metric socket and a prayer and it worked I was very worryed so I thanked the Lord for his help , and Question 2 on a lt1 Corvette the vent tube goes from the heads to the radiator are to the coolant tank I am doing a 94 LT1 and 4L60e swap into a 86 Camaro IROC Z I got a blown head gasket and the shop I took the heads too told me it had to do with the vent tube and where was it connect too thanks for your help
Old 10-26-2011, 05:31 PM
brioneschevybelair
I need pictures are diagrams on how vent tube connects to rest of cooling system are where it go form the heads on the left side to ??? and thank you for your help I have some diagram for the 93 94 it looks like it connects below the over flow on the radaitor and the other diagram it looks like it going to the throttle body but not sure
Old 10-26-2011, 06:35 PM
jaa1992
jaa1992's Avatar
St. Jude Donor '12
On my 92 there is a rubber hose that goes to a connection on the expansion tank.
Quick Reply: (LT1 Question) Installing a new rear coolant vent tube
