Can you just "hollow out" a catalytic converter with a broomstick?
Old 10-08-2015, 02:01 PM
TorchTarga94
TorchTarga94's Avatar
Originally Posted by kimmer
I have seen a few roadside emission checkpoints in my travels and they all had a wrecker ready to tow violators.
180 and go the other direction as quickly as possible.
Old 10-08-2015, 08:19 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Originally Posted by 1984Z51auto
Well, 13 years old or not,
This tells us that someone used the search function.
And resurrecting an old thread is using the historical value of this forum.
Old 10-08-2015, 08:59 PM
ex-x-fire
ex-x-fire's Avatar
I wonder if anyone has done this on an 84-85, remove the converter, cut the rear Y pipe so it can be lengthened, & bolt the rear Y pipe to the front one. Then you can weld in the rear sections going to the mufflers. I'd do it at the straight portion of the rear Y pipe.
Old 10-09-2015, 03:37 PM
HlhnEast
HlhnEast's Avatar
Originally Posted by Flame Red
I say a gutted cat is better than a cat any day.
Maybe my warped sense of humor but Maybe his as well!
Old 10-10-2015, 06:43 AM
Joe C
Joe C's Avatar
Originally Posted by gray84
Just wondering if this is true. And if it is, is it a good or a bad idea? Thanks-
I've got to ask, what are you trying to accomplish? I hope you don't think you'll gain any kind of significant boost in performance. my 2-cents, FWIW -- not a bad idea, but more of a dumb idea -
Old 10-10-2015, 07:56 AM
aklim
aklim's Avatar
Received 2,218 Likes on 1,932 Posts
Some people want the nose to "advertise speed", some have it plugged and don't want to pay to fix it. I tried running a test pipe and decided to install a Random Technologies cat because I was tired of the extra noise. I don't think it takes enough power away to count unless you are a race car where every little bit might help you win the purse.
Old 10-10-2015, 08:51 AM
Joe C
Joe C's Avatar
- that pretty much says it all.
I had a test pipe on my 85 when I purchased the car. i'm thinking the original owner installed it, since the 2nd owner only had the car for a short period. when I installed a new cat, I really didn't notice any, seat of the pants, performance gains. i'm thinking modern day cats flow a lot better than the stuff from the early days.
Old 10-10-2015, 10:10 AM
aklim
aklim's Avatar
I don't believe anyone can feel a increase in the SOTP dyno if it is as slight as 2 of 3 HP.
Old 10-10-2015, 10:34 AM
Joe C
Joe C's Avatar
- I've heard it takes about 20. probably better off with a good tune-up -
Old 10-10-2015, 12:05 PM
aklim
aklim's Avatar
20, likely. Never believed in the SOTP dyno. All it is good for is making people spend money in the belief they "feel" a gain.
Old 10-11-2015, 05:26 PM
whalepirot
whalepirot's Avatar
I don't believe anyone can feel a increase in the SOTP dyno.
I didn't.
Old 10-11-2015, 06:39 PM
ex-x-fire
ex-x-fire's Avatar
I see that a test pipe is available, common on Grand Nationals & L-69 Camaros/montes too. Weld a small y pipe to this to make your own Cat-less back system. This part is Pypes pvc10.
Old 10-11-2015, 06:55 PM
  #33
1963SS
1963SS's Avatar
If you used a broomstick my wife would have no transportation. It's the only way she flies.
Old 10-11-2015, 10:27 PM
  #34
aklim
aklim's Avatar
But it will drone so unless you have some sort of reason, I wouldn't. I did get pulled over for loud exhaust before. Sure, I got off but that is another story. It was the hassle.
Old 10-11-2015, 10:29 PM
  #35
aklim
aklim's Avatar
Big mouth you have when you know your wife isn't reading the forum.
Old 10-11-2015, 10:49 PM
  #36
crowz
crowz's Avatar
I couldn't tell a difference in my 86 pre and post cat gutting other than it was louder. 1/4 mile times were the same.
Which is strange since closing the power effects mufflers off to quiet mode killed performance compared to the wide open setting. But the cat had no effect other than noise.
Old 10-11-2015, 11:13 PM
  #37
aklim
aklim's Avatar
I doubt you will notice enough to justify it without a dyno to control variables.
Maybe the cat was NOT the choke point. Maybe the exhaust manifold was the choke point?
Old 10-12-2015, 12:25 PM
  #38
1963SS
1963SS's Avatar
Absolutely the truth. If she were to see this post she'd probably poke me in the butt with that pointy black hat of hers.
Quick Reply: Can you just "hollow out" a catalytic converter with a broomstick?
