1987 C68 Electronic Climate Control
Old 08-26-2009, 08:31 PM
BruceH
Cruising
BruceH's Avatar
Default 1987 C68 Electronic Climate Control
I have an 87 Vert with the C68 Electronic Climate Control. The abridged version of my problem is that the buttons, lights and temp display started to perform erratically and after unsuccessfully trying the cleaning processes documented here and elsewhere the unit was sent off for repair. The result of the repair was that the lights, buttons, and temp display now work, however, the fan does not work on either automatic or manual settings and the AC compressor does not engage, in other words the system doesn't respond to any of the inputs from the face of the unit.
In disgust I ordered a reman unit which upon receipt resulted in the heat and AC systems responding to the inputs from the control panel. However on this unit the "Warm" button did not function i.e. the temp could only be lowered using the "Cool" button, it could not be raised. Since both heat and AC responded to this unit I believe everything outside the controller itself is fine.
That unit has been returned and there are no more in stock for replacement so, now I've returned to the original unit and am seeking advice on diagnosing the complete lack of response to any inputs from the face panel.
Frustration abounds and I don't think this has been addressed from my searches, but I may be wrong and apologize in advance if this issue has been addressed.
Any assistance that can be offered is sincerely appreciated.
Thanks,
Bruce
Old 08-26-2009, 09:08 PM
rodj
rodj's Avatar
http://forums.corvetteforum.com/1568603057-post3.html
http://forums.corvetteforum.com/c4-t...to-remove.html
Old 08-24-2016, 08:16 AM
jered1
5th Gear
jered1's Avatar
Bruce, Please keep me in mind as I too am trying to solve my problem. My buttons go warmer but not cooler, on my 1987 Vette Conv. Jerry
Old 08-24-2016, 08:41 AM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
You've responded to a 7 year old thread with nothing "factual" regarding your issue other than a generalization. I believe you need to maybe consider mentioning what you've attempted for a repair. Be as specific as you can I believe describing what you've attempted.
Do you have the FSM for your car?
have you attempted "direct contact" with Bruce?
Old 08-24-2016, 09:39 AM
jered1
5th Gear
jered1's Avatar
NO FSM, I will find one online. thanks.
Old 08-24-2016, 10:33 PM
jv9999
jv9999's Avatar
The FSM isn't really going to help as it expects the dealer to replace the unit. Read this:
http://batee.com/corvette/acrepair/c68/
To 1987 C68 Electronic Climate Control
Quick Reply: 1987 C68 Electronic Climate Control
