90 Idles High---Still
When the car is running, the vacuum will hold it open and it will idle around 1500. If the car is not running, it returns fine. Engine vacuum, not a worn throttle blade, will hold it open. It is a new throttle body. I put springs on it that will help to overcome the problem but then you need a lead shoe to depress the accelerator pedal.
--I recently changed the motor, same problem
--I have unhooked the cables, same problem
--I have changed the coolant temp sensor, same problem
--I replaced the IAC, same problem
--I have replaced the throttle body, same problem
--I have replaced the TPS, same problem
Yesterday, I replaced the MAP sensor, unhooked the IAC and the TPS, turned the key to the "on" position for 3 minutes. Turned the key "off". Hooked the TPS and IAC back up. Started the car and it idled perfectly, drove it about 10 miles, perfect, idled down, perfect. I stopped and shut the car off, unhooked the one TB helper spring, (I was feeling good about it now) drove it a few more miles, perfect. Drove it another ten miles, IDLES HIGH UNTIL YOU KICK IT ONCE.. IT"S BACK...............
Do you have a scanner? I would set it off the IAC counts. Screw it in if the counts are high and screw it out if the counts are low. Aim for 15-20 counts. After that, set TPS if it is adjustable. Before all this is done, timing must be spot on.
The TPS is non-adjustable. I have not been able to try setting the IAC with a voltmeter. I have had it to several shops, thrown $100 bills at it and am trying to figure this out on my own now.
This is a throttle body from xtreme-fi. My concern is that it even has the right IAC valve. There is a difference between one for an 88 and one for a 90 even though the look the same. Without ordering another new one, I do not remember which valve is in the car. They look the same.....
Replaced the ECM. Reset the base idle. Took it for a 1/2 hour drive. Life seems goods again..............This has been very frustrating.
As I side note, while resetting the base idle, trying to unhook the EST wire, I think I un-hooked the right one. The tach does not work when it is unhooked. Oh well, the car is running good again. It is hard to drive keeping your fingers crossed.
I used to work on my stuff all of the time. Got to that point in my life that I would prefer to pay someone to work on it for me. Unfortunately, competent mechanics that are familiar with older vettes are few and far between. I decided to get my hands dirty and fix it myself.......now I know why I prefer to have someone else work on stuff.......
