Turn Signal Help
Turn Signal Help
My turn signals all work and light up. I replaced the signal flasher under the passenger side dash board. The hazards flash but when I turn on the turn signal lever the turn signals do not blink. Is there another signal flasher specifically for the turn signals and not the hazards? Please help. The car is a 1996 Corvette
You need to remove the driver side foot well panel and the turn signal flasher is located under the dash towards the left side of the steering column. The flasher you replaced was the hazard flasher.
I took off the driver side foot panel as well and didn't see it under there. But I will check again . When you say to the left of the steering wheel , do you mean the drivers side? I was upside down while under there haha. I really appreciate your quick response Hooked On Vettes. Go C.F.
The side of the steering column drivers door side. Not the transmission tunnel. Lay on your back and look up.
If it's the original factory flasher it should be silver in color and just plugged into a harness.
I'll post of pic. of it's location from the service manual in a minute.
