Porting ASM Runners
Porting ASM Runners
I want to build a 383 this winter, so I know I'm gonna need some aftermarket/porting done. I want to stay TPI
I already have the ASM's.
I am going to buy an aftermarket base and have that ported
And get a plenum from Corvetteplenum.com
Would it be best to have the ASM's siamesed?
Anybody know someone who ports? I know cuisinartvette does, but i don't know if he does runners.
If you want the runners opened up all the way through I would suggest Extrude Hone:
http://www.extrudehone.com/
I have had them do a couple intakes for me including a Dodge Viper intake and heads and the process is very good. Because the process uses an abrasive media, it is not selective as to where it removes the material but rather it removes it evenly throughout the runner or port so if you need a specific area addressed like changing a radius in a head, you will have to do that by hand first and then Extrude Hone once you are finished. For intakes with areas that are nearly impossible to get to and accurately open up Extrude Hone is the way to go. I haven't sent them anything in a couple years and it looks like they are owned by Kennemetal so I don't know if anything's changed, you will probably have to call them directly.
I don't understand how your going to port those runners. They are paper thin. You might be able to notch into the flange a little bit with some siamese work.
I also don't understand how the Corvetteplenum.com piece is different from the ported one you already have. It's a little rough but would be easy to smooth the port edges to runners.
The big base idea is good!
Are you going to use your short block? If not, I'll run it in mine when it blows.
Concur with Aardwolf's assessment. ASM's runners are thin-wall tubing - they are not cast aluminum like other big runners nor are they siamesed like most cast runners. They flow quite well as is and should support your 383 with a ported, aftermarket manifold.
First off, maybe look at a first system, or some different options IMHO.
I would focus on the motor, and worry about intake later. by the time you build a motor you might be able to have a better intake, or your plan might change.
I think by now you know LTR TPI set up is not a performance set up. I think if you are talking 383 you are talking at least superram if not HSR or mini ram. The LTR TPI in my mind robs or defeats the purpose of a bigger built motor. for those who speak of torque loss, look at HOLESHOT"s video of his 85' on youtube, with 383 miniram.( he also has gears though)
http://www.youtube.com/watch?v=B029yiXR2Hs
"The LTR TPI in my mind robs or defeats the purpose of a bigger built motor. for those who speak of torque loss, look at HOLESHOT"s video of his 85' on youtube, with 383 miniram.( he also has gears though"
exactly my thoughts.
St. Jude Donor '10-'11
383 TPI with Roller rockers, cam/heads, chip, bigger injectors, headers true duals, high flow cats, free flowing mufflers, Ported to the max asm runners/aftermarket base/plenum, slp cold air intake, and a better cooling system, you will have a bad *** motor in the lower-mid RPMs. The other set ups are for high RPMs. Honestly are you really going to obe hitting 5000 or more RPMs on a street car? Nope. Make the TPI the best you can. Get a good tune like from PCMFORLESS when your mods are all done and tear some tires up.
Almost forgot, get a D44 with gears. Expensive yes, but I am aiming for that set up.
that mini ram video shows he can burn robber no problem, and he will clean any LTR set ups clock under any circumstance even under 6k.
It is going to be a street car. I don't know about the SLP intake...no cats either
I eventually want to supercharge it, but that's going to be like 10 years down the road. I figure if I can donate plasma to make an extra 200 dollars a month and put it ALL towards a blower, I can have a supercharger kit in about.....25-30 months. NOT BAD!!
I think the only way to have the ASM's ported is going to be extrude honing. Has anybody ever done this? It sounds expensive...
Eh man, those boys are right - AS&M are thin. I could only get 1/4" on the top & bottom siamesed, and when i tried to go a little further on the bottom flange of one runner, I had to add a little permatex to it (made a hole). All is well as they are not a vacuum leak source, but they are way more thin than stock, for sure.
I am not going to be using my stock shortblock. There is someone local selling a bored/stroker clearanced block for 175 dollars. Cheaper than having my original block bored/hot tanked/clearanced.
You just read my mind.
i learned the hard way to stay away from LTR setups,i got a Super Ram and i dont discard a MR unit if i build a 383 or a 421 down the road.-
oh ..and im a street driver but i want to be capable of beat some azz on the track as well
