92 Instument Panel / CCM question
A while back the LCD portion of my 92's instrument panel started scrambling or going blank altogether (orange backlighting stay lit) when I would hit a bump, then it began doing it all the time.
I recently removed the instrument panel and cleaned all the contacts, as well as checking the socket in the dash board and bending all of the sockets to ensure good contact with the instrument panel connector.
The instrument panel appears to be working now, but a sharp rap to the dash board will still make the LCD go blank. I read in the Helm manual to check for codes 26-36 (maybe up to 38), which I had pulled when the LCD first began acting up (couldn't check them over the weekend, didn't have my cheat sheet to perform the procedure with me).
My question is, has anyone ever solved this problem by simply cleaning the contacts on the CCM plugs, or did it require replacement of the CCM?
I haven't had time to pull it yet to inspect anything on the CCM yet. Also, the schematics refer to G201 as the ground for the I/P, but I have yet to actually locate G201 under the dash. Any advice on where specifically to look?
And yes, I have searched the previous posts and pulled as much information as I could find before I started another post.
Thanks in advance to all who help!
Your cluster LCDs are flakey? Check with these guys
http://www.instrumentclusters.com/
They repaired my 91's cluster. This is a common problem, and maybe all they do is repair cold solder joints, but I got so darned fed up trying to fix it myself I sent it to them instead.
At the very end of the circuit diagram for each electrical section you will find a "component location" chart listing connectors, splices and grounds. My 93 book shows G201 to be located beneath the left side of the instrument panel on the kick panel. Hope that helps.
Stop hitting the panel you'll damage it.
To me it sounds like the connection on the LCD glass panel itself is intermittent. The 90-96 LCD panel connections can be tricky since they are just "pinched" on there and the contact points aren't really visable...any way it sounds as if you've lost tension at the contact point from what your describing.
Do not try to solder the glass connections....you'll need a new panel if you try that. Remove the panel and wipe the contact points with WD40, try to add a slight bit more tension on the connections that contact the glass panel, then slip the connector back on the LCD and reassemble the cluster.
Update - I pulled the codes yesterday and recorded the following:
CCM
C32 (ckt 1365)
C34 (ckt 1367)
C36 (ckt 1368)
C38 (ckt 1366)
H27 (ckt 1374)
H32
H34
H36
H38
ECM
H16 (I installed a Delteq Opti-Direct years ago, not sure if this is meaningful or not)
EBCM
Err (???)
I haven't had a chance to go through the troubleshooting flowcharts for the respective codes yet. Some steps require performing a continuity check between the I/P plug and CCM plug(s). I'll have to wait until this weekend to try that.
The "Err" code on the EBCM module is a little troubling, anyone seen that before?
Thanks,
Rick
CCM
C32 (ckt 1365)
C34 (ckt 1367)
C36 (ckt 1368)
C38 (ckt 1366)
H27 (ckt 1374)
H32
H34
H36
H38
ECM
EBCM
Err (???)
Thanks,
Rick
I have never
For repairs/replacements, stay away from Taber's -- bad news...
Thanks for the heads up on Taber's, so far I've only come across a few places that repair the instrument panel.
instrumentclusters.com not replied to me, business must be booming there...
Alright, I received a replacement I/P which appears to have taken care of the problem. My next problem is that I have been fighting to get the CCM seated properly in the right hand bracket. Apparently I will need to remove the right side of the interior to get the pins lined up in the rh knee bolster.
