Old 02-20-2015, 06:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Replacement Optispark and Water pump install - Part 1 (includes pictures)
Old 06-14-2016, 12:21 AM
  #161
ruby1993red
ruby1993red's Avatar
Is there a way to test the optispark to see if it bad?
Old 06-20-2016, 06:26 PM
  #162
92C4M6
92C4M6's Avatar
How much more would it take to install a cam?
Old 10-27-2017, 09:43 PM
  #163
Mark Gardner
4th Gear
Mark Gardner's Avatar
Default Electric water pump
So when you installed the electric water pump did you feel any difference.?
Old 10-29-2017, 01:43 AM
  #164
ChrisWhewell
ChrisWhewell's Avatar
Wow, those are some impressive photos, you should work for a magazine.
Old 04-14-2018, 06:55 PM
  #165
racerog1
racerog1's Avatar
Thanks for the great write up and EXCELLENT pictures!!! My 94 has 80k and has 'mis/stumble when hot' issue - but like others I'm replacing all the smaller/cheaper things first before I replace the opti-spark.
Any opinions about using aftermarkets, ie: MSD Opti replacements? I have been told to use Delco ONLY - right?
Old 04-14-2018, 07:13 PM
  #166
Whaleman
Whaleman's Avatar
https://www.ebay.com/itm/LT-1-Optisp...oAAOSwX9FZIPv2
I just installed an opti from the optidoctor (Brad) and the quality was extremely high. Check his other options on ebay. If you have an original with the Mits. sensor and you have time I would send yours to him and he will rebuild it and test it. You will get a video of the test with your name on the opti. Can't recommend any higher. Dan
Old 10-27-2021, 10:56 AM
  #167
Geovette350
1st Gear
Geovette350's Avatar
Thank you very much for photos. This must have taken a lot of time but is really of help to someone who is working on their opti LT1 for the first time.
Old 07-17-2023, 12:07 PM
  #168
Whoad_way_down
Whoad_way_down's Avatar
Default Thoughts on OptiJunk and Electric Water Pump
I had issues with 2 Optisparks and went to the Delteq conversion. The genius engineer who put a water pump over the ignition system should have been fired. I also had to change to Electric water pump as my car kept stripping the splines on the coupler. Hope you take a look at Delteq.
Frank
s
Quick Reply: Replacement Optispark and Water pump install - Part 1 (includes pictures)
