Where is the oil temp sensor on an 92 LT1
I can't even find it listed in the shop manual
Why do I need to change it?
Coolant temp by digital = 180 - 190
Oil Temp by digital gage = 100
I know the darn oil temp is closer to 200!
Any one have pictures of where it is?
TIA!
TIA!
Location: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Yup. In the most impossible place to reach behind the catalytic converter...Has to be done by feel.
Before you change it, though, my '92 does exactly the same thing. I changed my oil temp sensor and the reading didn't change, the gauge still reads very low. I've been told that it's in the dash cluster and that I should wait until something really goes wrong and then have the whole cluster reconditioned.
Could it be dash cluster ground related?
I am getting an intermittent Digital dash ground code.
I will have the exhaust off over the winter and may look for this elusive part then.
Also going to see if I can fix the dash grounds, the lighting is sometimes off.
A bad ground is a possibility, but I cleaned mine when I made the replacement and it didn't change a thing.
