Change oil light
Old 11-14-2009, 02:47 PM
94 Corvette
4th Gear
94 Corvette's Avatar
Default Change oil light
Is there a code to turn the change oil light off without going to a shop?
Old 11-14-2009, 04:09 PM
STL94LT1
STL94LT1's Avatar
Key on, no start.
Press "ENG MET" on the trip monitor, then again within 5 seconds.
Within 5 seconds press "Gauges", hold until change oil light stops flashing or goes out.
Old 11-14-2009, 05:35 PM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
Lots of good reading in the owners manual.
If you don't have one, you can download a pdf version here:
http://www.gmpartshouse.com/download...94corvette.pdf
Old 11-14-2009, 08:37 PM
Mrs. glass car
Mrs. glass car's Avatar
Do youself a favor and download or otherwise obtain an owners manual for your car. I have owned my 96 for over 13 years and still have to refer to the manual when reseting the light.
Old 11-15-2009, 03:09 PM
94 Corvette
4th Gear
Default It worked!
Thank-you!!
Originally Posted by STL94LT1
Key on, no start.
Old 11-15-2009, 03:10 PM
94 Corvette
4th Gear
Default Thanks for the info
Thank-you, I didn't get anything with the car as far as manuals. Thanks for the info.
Old 11-15-2009, 05:56 PM
MK 82
MK 82's Avatar
Here ya go!
Owners Manuals
To Change oil light
Quick Reply: Change oil light
