LT4 Hot Cam
LT4 Hot Cam
Hi I have a 1989 corvette with a 350 TPI (L98) and I wanted to put a cam in it. My main question is that if I replace the valve spring with LT4 valve springs and stick an LT4 hot cam in it do I have to change any thing else (such as something vitale that the engine will not run properly without.) I know that 1.6 rockers would be nice but they are not manditory, right? I am thinking of things more alonge the lines of lifters, rods, etc.
i'm running the LT4 HOT cam in my L98 with 1.5 RR, and it's fine. I am using aftermarket heads, but I think that may be beside the point.
I did change the pushrods since I went with guideplates and non-self-aligning rockers. another tangent.
to answer your question I think, no, the 1.6 RR are not mandatory.
With 1.5 rockers, the lift is .492. The cam will work, but I don't know if the LT4 springs will fit your heads. (diameter may be why) I'm sure there are after-market springs that will work.
A new computer-tune would kick it up a notch, too.
Recommended: Best to go with non-self aligning rockers with guide plates and hardened pushrods.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Gradustion Dasy Parade 20 May 2010!!!
It is similar to the ZZ4 with 1.5 rockers and also have the ZZ4 hot
cam springs good to .525.
I am using scorpion 1.5 rockers. I went with non-self aligning
hardened push rods and guides because it was a lot cheaper
and seamed to be a better setup to me.
I can round up some part #s if you are interested.
