700R4 vs. 4L60 (non-electronic)
Hello. I usually post over @ the C3 area, but figured you C4 guys (and gals) would have more/better info...
How do the 700R4 and 4L60 differ? I understand that the 4L60 is stronger, but others say it's identicle (only renamed). What years did the Vette come w/ the 4L60 (non-electronic)?
I appreciate the info :D
1 Post
Re: 700R4 vs. 4L60 (DR'76)
I'm pretty sure there is no such thing has a 4L60, and that any transmission that does not rely on electronic control that looks like a 700R4, is a 700R4. Just my humble opinion. :)
64Scout (07-31-2022)
There IS a designation of 4L60. It is a later used name for the 700R4. The 700R4 and the 4L60 are the SAMETHING. You say potato , I say potahto. The 4L60E is the later electronic version.
Re: 700R4 vs. 4L60 (CFI-EFI)
Received 1,400 Likes
Re: 700R4 vs. 4L60 (IcemanZ06)
Yup, theyre the same thing 4L60E is just electronic, only difference
Re: 700R4 vs. 4L60 (Bob86ZZ4)
I don't know if anyone on the Corvette Forum has done it, but I understand that the 4L60E when the engine has been modified quite a bit likes to have the PWM replaced with a more conventional vacumn modulator. Not on a stock or near stock engine, but one that is clearly operating outside the computer's parameters. Just a thought, I have no experience with this mod.
Thomas
Thomas
Re: 700R4 vs. 4L60 (vader86)
Re: 700R4 vs. 4L60 (drive it)
I think you can put a 4l80e in a c4. There is somebody either doing that right now or he has done it. I saw a picture around here somewhere of how he made a custom bracket on the tailshaft of the trans to bolt the torque arm to. I just tried searching around a bit for it and can't seem to find it. It looked cool tho. The 4l80e is much stronger than the 700/4l60e. Besides fabbing up the bracket you need some sort of other computer to control it because it needs electronic controls for shifting.
The 700R4, 4L60, and 4L60E, are basically an over drive version of the TH350. The 4L80E is the over drive equivalent of the TH400. The 4L80E was never made in a non-"E" configuration. The differences between the "60" series and the "80" series are very similar to the differences in the TH350 and the TH400. The 80 is bigger, longer, and heavier. Transmission tunnel clearence MAY be an issue in some applications. Jet Performance and others are providing transmissions with electronics for coversions. They are a beefy trans, but they ain't cheap.
[Modified by CFI-EFI, 1:44 PM 3/4/2002]
NONE of the parts from a TH350/400 can be used in ANY 700R4/4L60/80/E model. They are TOTALLY different beasts.
