Need help 1993 theft deterrent system -
5th Gear
Purchased 1993 corvette - has a resistor link in vats key system. Car starts for a second and dies - suspect theft deterrent system. Evidently the 93 is different from the 89 - cannot use the vats bypass module - so - how do I delete the vats security? Can the ECM E-prom be reprogrammed to omit vats completely or what can I do?
I agree with Surfer, it shouldn't be the VATS. Flashing light could be a bad door switch, possible it is unrelated coincidence. Don't assume because the pump is new it is working OK, need to check the pressure and make sure. Were you having this problem before you replaced the filter and pump? (are you sure the filter isn't backwards?)
