Exhaust comparison Flowmater, Magnaflow &Headman Elite (videos)
Exhaust comparison Flowmaster, Magnaflow &Headman Elite to LT1 (videos)
I am upgrading my exhaust to Magnaflow cat back.
My current exhaust is stock with Flowmaster 40 series and TPIS YPIPE.
this is the thread that got it started.
http://forums.corvetteforum.com/c4-t...15658-a-2.html
Here is the new exhaust
Here is the first video.
Stock exhaust with Flowmaster 40 series 2 chamber and TPIS Y-pipe.
Why don't you run tru dual 2 1/2 with the x-pipe. You can still use the rear section of the y-pipe just have the muffler shop cut the collector section, but you well have to buy different cats..
BTW I have a hard time trusting others to work on my car
I have the headers on now.
I have put on a lot of headers in my time and never had any that bolted up and fit perfect until today.
I took the plugs,wires, and starter off. I took the S-belt off and the 4 long screws that hold the A/C compressor in place and moved it. The drivers side slid in from the top easily. The passengers went in from the bottom just as easy.
TPIS uses a Y Hooker used a Y..
PICS:
TPIS
HOOKER
look at this: http://forums.corvetteforum.com/c4-t...nt-y-pipe.html
Speed Racer X (12-14-2023)
When I do long tubes, (after waxing off and on for awhile) it will most likely be the Hed elites.....what did you give for them, and from where if you don't mind me askin'? And this is the first time I have actually heard that they fit good (yay!).
I have the same ones going on 2 years and still has the same finish. No problems with install. I did go through the supplied gaskets right away. Install some stage 8's and you're good to go.
