LT1, what are the specs for a set of roller rocker arms do i buy?
7/16 and self alignning are these the proper specs for replacements roller rocker arms for my 94 LT1?
thanks boonie
thanks boonie
If you buy 7/16" NSA rocker you will need rocker studs (7/16" of course)
hardened guide plates and hardened pushrods (polylocks too)
If you are changing to 1.6 from the stock 1.5s be safe change the springs too.
Good luck on your swap.
So, I'll strongly recommend it once again: If you're buying new rocker arms, go with 7/16" NON self-aligning rockers, 7/16" ARP studs, hardened pushrods and guide plates.
You can thank me later, LOL.
Jake
