Be aware of Rain-X Latitude wiper blades!
Be aware of the Rain-X Latitude wiper blades. I bought a set for $35.00 today. With all the rain here in WA state, i needed a new set. The problem with the blade is not the performance, they work very, very well. Its the adapter on the blade itself, as you can see in the link below. Its such a fat, tall mount that when you turn off the wipers, and the blades stow, the mount hits and gets stuck under the front side of the hood. This causes the blade to pop up pretty hard when you first turn them on. I will try and grind down some the fat mount and see what happens. Or go back to OEM. Hopefully this post will prevent others form installing these wiper blades on there cars!
http://www.rainx.com/Products/Wiper_.../Latitude.aspx
Received 3,043 Likes
St. Jude Donor '05
Most the replacement arms hit the hood found its better to replace the blade only.
Here are some that are known to work:
Trico Exact Fit
Trico Teflon
Anco Aerovantage
Dealer 95-96
I wouldn't get the 84-94 dealer blades. They are flimsy, and the ends are too tall and don't fit in the wiper blade catch for the driver blade.
I would also say the regular Anco blades would probably work too. I've also heard the regular Rain-X blades work.
Duralast and regular Michelin blades look like they would be low enough too, but I haven't tried them. I'd probably just get Trico anyways.
Check this out... http://forums.corvetteforum.com/c4-t...f-the-day.html
Awsome! Just what I was looking for!
St. Jude Donor '05
True...
My Rain x blades work fine
I looked at your link and I must have the weatherbeaters. They fit great and no problems with the hood. Maybe the latitude model is taller?
As far as arms go, I haven't seen them sold with the blades, the arm would be very expensive in comparison.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Thanks, I was looking at those. Guess I`ll stick with the $3.99 Pylon brand from Wally World. They work great on all my other cars.
