96 LT1 Stumbles @ low RPM
Had been running good for some time but have noticed a Low RPM stumbling that is getting progressively worse over the months.
96 LT1 / 80,000 miles .. No MIL codes are noted and Engine idles smooth
-- replaced MAP sensor and MAF
1) Most noticeable around 45 / 50 @ 1200 RPM and a slight throttle increase.
2) IS not noticeable in closed loop / prior to warm up.
3) When fully warmed up and on the road, if RPM is low and WOT, engine will stumble and may die.
4) If RPM is higher than ~ 2000 while in neutral while warm and WOT is hit, engine may stumble a little but will not die.
5) WOT and full power during drive time are OK as long as engine RPM is higher than ~ 1200
6) When the problem is occurring, for example, when I go WOT and RPM is low, it sound like a few cylinders are misfiring.
This does not seem to be a fuel problem and the MAP and MAF has been replaced with no significant difference.
Any suggestions before I replace the opti spark unit ?
Thanks in advance.
Thanks in advance.
My car does exactly the same thing and I mean exactly the same it happened right after I accidently wet the optispark by mistake. I'm changing the optispark soon
Let me know what you find. My '95 will chug and knock at low rpm in 6th gear while trying to accelerate. Sounds and feels as if I had the wrong grade gasoline in it, but that's not the issue. I don't want to toss $$ at it hoping to fix it.
Mike
Mike
Joetrackside (09-08-2021)
Thanks in advance.
Thanks in advance.
Plugs
Plug wires
Opti
Pretty easy to inspect the first two.
Because this only happens once the car is warmed up in closed loop and using signals from its sensors to run the motor, there's a problem with one of the sensors. You can do resistance tests etc. to narrow down the culprit. For example, simply unplug the egr to test.
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
2020 C4 of the Year Finalist - Unmodified
2019 C4 of Year Finalist (stock)
I would suspect either o2 sensor or optispark. My opti developed a crack in the housing and when it warmed up things spread far enough to make it run erratically.
SImilar issue. Drove it after a rain on wet road after Henri blew through, it started to sputter sitting in drive at idle. but not noticeable in neutral. it must have kicked some mist up to the opti.. after I washed the engine one day I drove it with the hood unlatched and woosh it seemed to clear up.
Similar problem here too. Replaced the plugs, wires, opti (it got wet), ICM, IC (it died a couple years ago), injectors (that solved another issue) and even the IAC. Still idles too low. I still have the drivers side o2 sensor to replace, i can't seem to get that off without a lift.
