O2 sensor
Old 04-16-2010, 10:30 AM
kmhene
kmhene's Avatar
Default O2 sensor
Do I need to reset the computer after installing O2 sensor?
Have an 84 with CFI so I only need to install sensor.
And when you guys say reset computer your refering to disconnecting the battery right?
Thxs
Kevin
Old 04-16-2010, 11:14 AM
car5car
car5car's Avatar
no
no
Old 04-16-2010, 11:33 AM
onedef92
onedef92's Avatar
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
No, you don't have to clear the ECM by pulling the negative battery cable or ECM fuse for 30 seconds. Just install the sensor.
I would use a little anti-seize compound on the new sensor's threads, though, taking care not to get any on the sensor end of the unit.
To O2 sensor
Quick Reply: O2 sensor
