'85 heater acting weird....any ideas? - CorvetteForum - Chevrolet Corvette Forum Discussion
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine
Old 03-17-2002, 06:11 PM   #1
rxbdwl
CF Senior Member
rxbdwl's Avatar
Default '85 heater acting weird....any ideas?
My cars been in the paint shop about all winter so I decided it needed a little excercise today. I drove about twenty miles and stopped about twenty minutes then drove another thiry and all was fine. I then stopped about an hour and a half. Then drove about thirty miles and had no heat. Blower worked fine if you count cold air. Water temp was normal. I then stopped for dinner for about another hour and a half (slooooow service) and when I headed home the heater was fine all the way (about fifty miles). I checked the water when I got home and the level is fine.
I was stumped when it quit working. Then when it started again I was totally stumped.
Any of you gurus out there have any idea what is going on?
rxbdwl is offline   Reply With Quote
Old 03-17-2002, 07:51 PM   #2
Bluevette85
CF Senior Member
Bluevette85's Avatar
Default Re: '85 heater acting weird....any ideas? (rxbdwl)
Try filling your radiator this way. Take cap off and run engine until thermostat opens. Turn heater on hot. Have a helper idle the engine about 1200-1500rpm. You should see the coolant level drop. Fill it up and replace the cap before letting off the idle. Your cooling system will now be full. This assumes that your system isn't dirty or clogged. You may want to flush it first.
Bluevette85 is offline   Reply With Quote
Old 03-18-2002, 05:50 PM   #3
rxbdwl
CF Senior Member
rxbdwl's Avatar
Default Re: '85 heater acting weird....any ideas? (Bluevette85)
Thanks Bluevette. I don't really think it's low but I'm stumped on what happened. I suppose if it was low the heater core could have kind of air locked. At any rate I'll give it a try.
Old 03-18-2002, 05:55 PM   #4
fiddleplayer
CF Senior Member
Passenger side next to the heater blower motor is a vacuum accuated valve. either the vacuum is not there, the diaphram is leaking or the valve is stuck. I usually have to move mine by hand after it has set for a while or I just tie it open with a ty-wrap.
fp
fiddleplayer is offline   Reply With Quote
Old 03-18-2002, 05:58 PM   #5
Bluevette85
CF Senior Member
It can be deceiving and look full. Mine took another 3/4 gal when I filled it this way.
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • '85 heater acting weird....any ideas?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Engine stuttering horrible - Hzuddy C5 Tech 13 08-24-2015 11:05 PM
    93 LT-1 unidentified brake trouble-any suggestions? drumking241 C4 Tech/Performance 29 08-18-2015 01:07 PM
    Water pump / thermostat do they go bad with no warning 327carguy C5 General 8 06-14-2015 10:24 AM
    Z06 hesitating on throttle, occasional white smoke, hard start totally random gatti-man C6 Z06 Discussion 88 02-20-2015 12:15 AM
    C5 overheating one-ate-6ix C5 General 14 05-08-2013 11:55 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
