Custom built C4 analog gauge cluster
Old 05-23-2010, 02:23 AM
Vintagevetter
Vintagevetter's Avatar
The lack of analog gauges has always been one of my two gripes about my C4...the other being that steering wheel that looks like it came out of grandma's Buick ....LOL...I have a 94 coupe
I would think it would be a real bear rewiring everything behind the dash....it would be nice if an aftermaket company could come up with an analog panel that was "plug & play" To keep it looking more OEM...perhaps they could use C6 gauges.....just a thought..
Old 05-23-2010, 10:11 AM
theafus
8th Gear
theafus's Avatar
I like my analog guages as well
Old 05-23-2010, 10:19 AM
drjimmy
drjimmy's Avatar
I went that route myself. Very happy with the results. Nice job Quickvette84.
theafus
8th Gear
theafus's Avatar
Originally Posted by 'Shifter
Too cool....I wish there was a reliable company that made panels for our cars...
There is I got my harness from them. Made my dash though.
http://vettaid.com/
Old 05-23-2010, 12:40 PM
Mr6spd
Mr6spd's Avatar
http://vettaid.com/
How much was it for just the harness?
Old 05-23-2010, 02:22 PM
Firevette
Firevette's Avatar
Cruise-In X Veteran
http://vettaid.com/
Looks like they have a 90-96 unit in the works.
Old 05-23-2010, 02:37 PM
theafus
8th Gear
theafus's Avatar
I think I paid 75 bucks for the harness but man was it an easy swap I spent more time making the dash and mounting the gauges well thats probably cause I am ****
Old 05-23-2010, 06:12 PM
ch@0s
ch@0s's Avatar
If you get one can I Borrow it when ur not using it?
Old 05-23-2010, 08:41 PM
pologreen1
pologreen1's Avatar
Old 05-23-2010, 09:15 PM
666Vette91
666Vette91's Avatar
Default 1984-1996 LCD Dash Replacements
Corvette America has them Very costly though.
These dashes are precision-cut and powder coated for an excellent fit and finish. They are then fitted with Auto Meter gauges - wired to be fully functional as a true plug and play component. Comes with instructions on how to remove and replace your existing dash.
The Auto Meter Gauges are fully electronic, but with a classic, analog look and feel. Programing and syncing is simple, and explained in the instructions. You can choose either a six or eight gauge dash fitted with Phantom (white face) or Sport-Comp (black face) Auto Meter gauges.
Old 05-24-2010, 08:49 AM
ks5shooter
Support Corvetteforum!
ks5shooter's Avatar
St. Jude Donor '10-'11-'12-'13
Old 05-25-2010, 08:48 AM
Quickvette84
4th Gear
Quickvette84's Avatar
Polishing is taking a while, I might go to a textured black powdercoat, I can get whatever I want powdercoated at my work for free. I have the dash all drilled and ready. I am having a c4 emblem engraved into the dash between the speedo and tach. should look pretty sharp. More pics to come. I saved the CNC file I plasma cut it with.
Old 05-25-2010, 03:42 PM
  #33
DanZ51
DanZ51's Avatar
Wow, these are some beautiful dashes. If the guages themselves didn't add up so fast $$$ I'd be all over this. I can fab a panel and do the wiring (without a kit).
What size guages are some of you using 3.5", 5" ?
Old 05-26-2010, 06:07 PM
  #34
Quickvette84
4th Gear
Well here is a pic of the gauge pod after engraving the corvette emblem on a CNC mill at my work, still have some wet sanding and polishing to do. I went with 3.5" for speedo and tach and 2 1/6" for rest of gauges, blue LED for high beam and green LED's for turn signals really clean look. Should be installed in the car by this weekend.
Old 05-26-2010, 06:10 PM
  #35
theafus
8th Gear
theafus's Avatar
3 3/8 speedo and tach and 2 1/8 for the other gauges
Old 05-26-2010, 06:11 PM
  #36
theafus
8th Gear
theafus's Avatar
thats sweet wish I had access to a CNC
Old 05-26-2010, 10:32 PM
  #37
Gazpar
Gazpar's Avatar
Very cool!!
To Custom built C4 analog gauge cluster
Old 05-26-2010, 11:02 PM
  #38
qws
qws's Avatar
But now they offer them at
Corvette Central and Midamerica
http://www.corvetteamerica.com/cf/di...ord%3A%2050145
Old 05-27-2010, 12:50 AM
  #39
856SPEED
856SPEED's Avatar
Jesus.........I just ordered one............
Old 06-04-2010, 05:26 PM
  #40
Quickvette84
4th Gear
Well I have it installed now, I have to still clean it up but here is a pic of it in the car
Quick Reply: Custom built C4 analog gauge cluster
