Custom built C4 analog gauge cluster
Old 09-18-2010, 01:46 AM
  #61
USAsOnlyWay
USAsOnlyWay's Avatar
Originally Posted by mattwalker87
me? the smaller one on the top left by headlights is the foglight switch. the one to the right where the info cluster was(actually theres 2 side by side and a gauge over there) is for the front air ride.
Ah got it, thanks!
Old 09-22-2011, 06:39 PM
  #62
87bob
87bob's Avatar
Originally Posted by Quickvette84
So I am in the process of switching to analog gauges in my 84. Spent all day wiring today, still have to polish the aluminum plate and finishing mounting brackets. Thought I would put a picture of the dash so far before I started polishing the aluminum, I am going to post more pics as I get farther along
I would be real curious to see the wiring. How difficult is it? How did you mate up the harness to your gauges?
Old 09-22-2011, 06:47 PM
  #63
87bob
87bob's Avatar
Front Air Ride do explain?
Old 05-31-2015, 07:41 PM
  #64
pologreen1
pologreen1's Avatar
Originally Posted by 856SPEED
Here's mine installed....
http://forums.corvetteforum.com/pict...ictureid=57060
having problems at low speeds with it though.....speedometer wants to jump around at speeds below 45-50mph......hi beam light is extremely bright.....light for the water temperature does not work......Jody from Vett Aid has been very good about responding to these issues, though......seems like a class act......
Interesting, anymore issues with this or did it get taken care of? Total cost?
Old 05-31-2015, 09:53 PM
  #65
v8vette84
v8vette84's Avatar
Old 05-31-2015, 11:49 PM
  #66
Colonie 91 Vette
Colonie 91 Vette's Avatar
Originally Posted by theafus
There is I got my harness from them. Made my dash though.
http://vettaid.com/
Love your new dash. Any opinion on whether moving to an analog dash devalues the car? Vette Aid dashes look great to me.
Old 06-01-2015, 07:32 AM
  #67
856SPEED
856SPEED's Avatar
Wow........I remember this thread.......
I still have the dash in the car and overall, it's great and I would never go back to the 1980's Atari dash; it doesn't fit the car anymore and the tach alone is worth the change.......Especially since I chose the white face Phantom Autometers and my car is white with a blue stripe and I plan to change out the interior to blue/white soon.
Having said that, I have had a couple issues with bulbs burning out (not in the gauges) but the high beam light (originally was WAY too bright), and my water temp. gauge light also went out.....the speedo has an erratic needle and low speeds (below 40mph) before it levels out;
I have heard it is a grounding issue on ALL the accounts above and the speedo needs a buffer as it is possibly getting an interference on the pulse counts at low speeds......
on my bucket list to fix when I do the interior.......it's a project car....one thing at a time!
Vette Aid I must say has been good to work with; Jody always is there to speak with, but I am not sure these things were ready to come out of the oven when they did back a few years ago.....He even sent me a new speedo but to no avail; same thing. Just decided I have had it this long, I will fix it (like other things on a 30 year old car).
As far as value on a C4; my car is much better in all respects than when I bought in 2001; I would pay more for this modified 85 with upgrades parts/performance than I would for a stock 85 any day....
I would rather have a 6 speed/400hp 85 than a 230 hp 4 speed car all day long........
Old 09-08-2015, 02:39 PM
  #68
UserG
UserG's Avatar
Wish I knew how to make new gauges
Old 09-09-2015, 04:41 AM
  #69
HlhnEast
HlhnEast's Avatar
Me too. You wanna start over??
Old 09-09-2015, 05:03 PM
  #70
87bob
87bob's Avatar
The early C-4 is the easy one to make the custom gauge cluster for Its a matter of bending a piece of Aluminum and cutting the holes. I am working on two C-4's right now and plan to do custom for both of them. I'm planning something a little trick so I'll just monitor this thread and see what pops up. That is what is nice about C-4's their cheap and parts are easy to get.
Old 09-09-2015, 09:20 PM
  #71
mtwoolford
mtwoolford's Avatar
Originally Posted by 94z07fx3
Is it called burnishing when one takes a drill with a wire brush and makes uniform overlapping circular patterns in metal?
it's proper name, and it's a very old term, is "engine turned"
Quick Reply: Custom built C4 analog gauge cluster
