L98 speed density affordable mods
Hi, I want to know how much power can I make with this mods ?:
Stock heads, bottom end
accel big mouth,siamese runners,ported plenum,stock body throttle
zz4 roller cam 1.6 roller tips
hooker headers
A suggestion (cam,etc)
hooker headers
Cruise-In II Veteran
Re: L98 speed density affordable mods (Eduardo L98 1991)
Eduardo, I think you would gain somewhere around 60hp and alot of torque with that combination. the ZZ4 cam works good with the TPI but you will have to change the valve springs! add a set of 3.07 gears and hang on :D :cheers:
Re: L98 speed density affordable mods (WINNER)
Thanks for your answer
NO, I don´t want to change gears.
What brand of springs, Can I buy it in Summit or a better place ?
I saw that I need to change spring with almost any aftermarket cam why ?, the oem springs are soft ?
I want to have 300 rwhp, can I ? with stock heads ?for daily use
Let me know
regards
Let me know
regards
Match the springs to the cam. A new cam or even 1.6 RRs requires new springs and shims due to increased lift and higher seat pressure requirements. Also springs age and should be replaced to avoid valve float.
OEM springs are rated to give maximum valve train life within the stock RPM and valve lift range.
I suggest you hand port your #113 heads, and work them per the data I've sent you. Standard Abrasives has a kit and video as well as an informative site on head porting.
If you implement all the mods in the list you should have very close to 300 rwhp and it should be an excellent daily driver.
Re: L98 speed density affordable mods (65Z01)
65zo1:
Thanks for your answer.
I don´t receive the date.
What springs I need ?, pressure ?, brand ?
Another cam suggestion ?
regards
regards
I sent you e-mail with the "Corvette Fever “HP Conspiracy” Article Summary" data. It has data from two TPIS cams installed in a '90 L98. Their catalog suggests correct springs for each cam.
The install height and the spring factor determines the install pressure. You can get spring shims from Comp Cams or other cam manufacutrers. I'm running the stock cam so don't have any personal experience or data on cam selection.
This is the first time that I don´t receive alot of asnwer from you ?
What happened ?, Spring break vacations ?
I also want to know if the L98 heads are the same heads as the zz3 engine.
To buy the zz3 springs ?
All of this is only to know about it !
The headers and intake is a reality but I want to kow your opinions ?
let me know
regards
let me know
regards
