Help replacing aftermarket antenna
Old 06-08-2010, 12:39 PM
lmplain
2nd Gear
lmplain's Avatar
Default Help replacing aftermarket antenna
I have a 89 convertible and the old antanna was beyond repair so I picked a new one up at an auto parts store. Modified the top so it would lay flush with the top of the car but for the life of me I can't figure put how to wire the darn thing. It's only 4 wires including a ground on both the car and the new antenna. Anybody got any direction for a guy who has drank way too many crown and cokes and scratching his head for too many hours trying to figure this one out?? HELP!!
Old 06-08-2010, 03:27 PM
AGENT 86
AGENT 86's Avatar
With your new antenna's wiring schematic and this PDF, you may be able to figure it out.
http://dankai.shawwebspace.ca/asset/...er_antenna.pdf
You might find help from Hooked On Vettes reply, here.
http://forums.corvetteforum.com/c4-g...r-antenna.html
Old 06-08-2010, 04:09 PM
lmplain
2nd Gear
lmplain's Avatar
Thanks Agent 86 for the info. Looks like a couple crown and cokes and a new game plan. Sounds like I don't have to worry about 3 of the wires per the response from hooked on vettes. Part of the problem is that I guess I assumed every wire needed to be connected to something....guessed wrong.
Thanks again
To Help replacing aftermarket antenna
Quick Reply: Help replacing aftermarket antenna
