Despite spenting over $800 and being full of feon my A\C dosen't blow cold air: why?
I've spent over $800 in the past 1.5 yrs to get this A\C system to work properly now despite the fact that it's full of freon it now blows out air that's not really cold "last year my A\C worked great" my 94 4cyl Toyota PU A\C will freeze you out and the only thing that i've done with it in the last 5 years is to put 1 can of freon, go figure! the compressor dose it's recycleing properly "i've also notice that my engine surging when A\C is on" still no cold air, what should i do to correct this problem? because I can't continue to throw my good money into this problem. Should i return it to my orginal Corvette mech for another shot at it or try a A\C repair shop?
thanks boonie
PS are C4 Corvettes cursed with defected A\C systems?
thanks boonie
thanks boonie
thanks boonie
I don't know if 94 cars work the same way but earlier C4's (and a lot of other vehicles) have issues with their blend doors. It's a door that, depending on position, controls how much heat/cold air gets in the cabin. When swung all the way one direction, it covers the heating source and blows the coldest air. The opposite direction allows the hottest air. For electronically controlled (w/thermostat), air can be somewhere in-between.
It could be your A/C is working fine but your blend door is letting in heated air along with it.
When was the last time your system was charged. I know you said it was full but if it was last year when you had it charged it could have leaked down some. let me know
I'd suspect a Blend Door Problem too, but the fact that it's surging means it isn't reacting to the a/c request (correctly) or the compressor is putting a huge load on the system, so scanning it should be on your list of things to do first. Also, what did you have done? CA requires shops that do a/c work to provide you with a detailed description of their services and to note operating pressures, center vent temp and outside air temp and if they didn't do that, you may have redress through the B.A.R. Letting us know what you spent $800 for could help.
