How do you adjust the parking brake on a '92 C4?
Old 07-06-2010, 08:52 AM
mundo
mundo's Avatar
Default How do you adjust the parking brake on a '92 C4?
Changed rear brakes. The pads were credit card thin. The parking brake was tight. We changed pads. Now there is a burning smell and the rear rims get hot. The parking brake was obviously adjusted for the paper thin pads. Where is the adjustment and what's the procedure?
Old 07-06-2010, 10:43 AM
sailorsteve
Support Corvetteforum!
sailorsteve's Avatar
Your '92 has an automatic parking brake adjuster on the lever assembly, but it looks like it wasn't reset when new pads were installed. The FSM details how to do this in typical cookbook fashion.Can you get your hands on one?
Old 07-06-2010, 01:50 PM
mundo
mundo's Avatar
In lieu of the FSM does anyone know how to adjust the parking brake.
Old 07-06-2010, 02:09 PM
sailorsteve
I have the FSM, I can try and copy the pages and send them to you.
Old 07-06-2010, 02:13 PM
braeburn22
braeburn22's Avatar
Parking Brake Automatic Adjuster
PARKING BRAKE
This vehicle is equipped with coated parking brake cable assemblies. The wire strand is coated with a nylon material which slides over plastic seals inside the conduit end fittings. This is for corrosion protection and reduced parking brake effort.
NOTE: Handling of these cables during servicing of the parking brake system requires extra care. Damage to the nylon coating will reduce corrosion protection and if the damaged area passes through the seal, increased parking brake effort could result. Contact of the coating with sharp-edged tools, or with sharp surfaces of the vehicle underbody, should be avoided.
Parking brake lever/cable adjustment is automatic. Cycling the lever three times should result in parking brake lever movement of 3 to 5 notches when a 270 N (61 lbs.) force is applied.
PARKING BRAKE AUTOMATIC ADJUSTER
Disabling the parking brake automatic adjuster is necessary to loosen the parking brake cables for maintenance of the parking brake system. The parking brake automatic adjuster must be enabled and cables adjusted (tightened) after maintenance has been completed.
DISABLING PARKING BRAKE AUTOMATIC ADJUSTER
1. Remove driver's seat cushion.
2. Remove parking brake lever cover and screws.
3. Using fabricated wire, or an offset screwdriver, hold drive pawl so that it is disengaged from drive sector.
4. Insert a nail, or drift, through the hole in the anchor plate to retain the drive pawl in the disengaged position.
5. Move the parking brake lever until it aligns with lock pawl.
6. Depress button on lever and move lever to down position.
7. Visually inspect to see that anchor plate is against the stud on the parking brake lever. NOTE: If anchor plate is not against stud, repeat procedure as needed.
8. Parking brake front cable can now be pulled to the rear to gain the slack necessary to perform parking brake maintenance.
ENABLING PARKING BRAKE AUTOMATIC ADJUSTER
1. Remove nail, or drift, from anchor plate.
2. Apply and release parking brake three times.
3. Pull up on parking brake lever. NOTE: Proper lever/cable adjustment will result in the parking brake lever moving up 3 to 5 ratchet clicks with a 270 N (61 lbs.) force.
4. Release parking brake lever. There should be no rear brake drag and no gap between the caliper housings and caliper parking brake levers.
Old 07-06-2010, 03:33 PM
mundo
mundo's Avatar
Thanks Breburn22!
Old 05-18-2014, 11:59 AM
Don85corvette
3rd Gear
Don85corvette's Avatar
PARKING BRAKE
Thanks! What you wrote was very informative and helpful, just one thing you and anybody else that described this procedure, failed to mention is you have to remove the entire seat assembly.
Thanks Again,
To How do you adjust the parking brake on a '92 C4?
Quick Reply: How do you adjust the parking brake on a '92 C4?
