700R4/4l60E Slip Yoke Question
Old 07-12-2010, 08:05 AM
Pete K
Pete K's Avatar
Default 700R4/4l60E Slip Yoke Question
Old 07-12-2010, 08:27 AM
PDQUIK95
PDQUIK95's Avatar
Location: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Pete,
Just a thought.
You might try Denny's drive shaft for info on a new yoke.
They provide suitable yokes with their new shafts.
Rick
PS: I have also machined the sleeve length down on a longer yoke once to suit the shorter tail shaft/housing application before.
Old 07-12-2010, 08:43 AM
mseven
mseven's Avatar
I would check these guys out...got mine from them.
http://www.dynotechengineering.com/
Old 07-12-2010, 12:48 PM
toptechx6
toptechx6's Avatar
I just tried looking up the part number for a factory replacement and it is listed as NS (not serviced) part of prop shaft assembly; looks like a drive shaft builder is your only option.
Old 07-12-2010, 01:11 PM
engle1147
Support Corvetteforum!
engle1147's Avatar
I tried to buy just a "vette slip yoke" about 10 years ago and had to buy and entire assembly (yoke, joints, shaft)from the stealership.
It is also possible to have a "groved" slip yoke turned down slightly then cromed up & polished to restore the origional diameter. Isn't cheap though.
Old 07-12-2010, 01:19 PM
mseven
mseven's Avatar
Originally Posted by Pete K
Thanks Mick. I could not find it on the website, but I will call them.
That's were mine came from as well as all dana/spicer, marc williams etc. parts
Old 07-12-2010, 06:15 PM
slickfx3
slickfx3's Avatar
my shop chopped mine down, 1/8" to 1/4" when I did the swap and called it a day...
Old 07-12-2010, 09:45 PM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
Dropped you a couple PM's.
To 700R4/4l60E Slip Yoke Question
Quick Reply: 700R4/4l60E Slip Yoke Question
