1995 Fuel Pressure Regulator
Old 07-19-2010, 07:57 PM
dmorford
Cruising
dmorford's Avatar
Default 1995 Fuel Pressure Regulator
What are the symptoms of a faulty fuel pressure regulator. My car is running very rough (galloping at an idle). The fuel pressure is 41 psi with switch on and engine off. While running the fuel pressure varies around 38 psi.
Old 07-19-2010, 10:15 PM
aminnich
aminnich's Avatar
Your pressure readings are right where they should be. Possibly the IAC needs cleaned.
Old 07-19-2010, 11:00 PM
jsdomino
jsdomino's Avatar
Check for a vacuum leak
To 1995 Fuel Pressure Regulator
Quick Reply: 1995 Fuel Pressure Regulator
