Racetronix / Walbro C4 Fuel Pump Kit Sale
Supporting Vendor
15% OFF ALL RACETRONIX / WALBRO 255LPH HIGH-PERFORMANCE C4 FUEL PUMP KITS
FPA-009H, 1984-1985 C4 Corvette Fuel Pump Assembly, Performance 255LPH
FPA-010H, 1990-1996 C4 Corvette Fuel Pump Assembly - Performance 255LPH
FPA-011H, 1986-1989 C4 Corvette Fuel Pump Assembly - Performance 255LPH
C43 1984-1988 Fuel Pump Wiring Harness
C44 1989-1996 Fuel Pump Wiring Harness
(C44 harness shown below)
BUY ONE OF THE FUEL PUMPS KITS ALONG WITH A C43 OR C44 HARNESS LISTED ABOVE AND RECEIVE A FREE RACETRONIX T-SHIRT USING PROMO CODE C4-FPA WHEN YOU CHECKOUT OF OUR WEB STORE. PLEASE ONLY ONE SHIRT PER PURCHASE. QUANTITIES ARE LIMITED.
T-SHIRTS
*** QUANTITIES ARE LIMITED ***
(C44 kit shown below)
- Walbro 255LPH HP Pump
- Filter sock - 30 micron filtering (factory=70 micron)
- New Teflon in-tank wiring
- Terminal lock
- High pressure fuel line
- Stainless gear clamps
- Rubber pump mount
- Pump sound insulation sleeve
- C4 fuel tank gasket
- Stainless hex-head tank bolts, washers and o-ring seals ( 9 pieces)
- Hex key
- Silicone grease
T-SHIRTS
Walbro will supply the fuel volume needed for higher HP motors. When I did my heads/cam intake, I found the stock pump was not getting the job done at high RPM. FP was dropping and wideband showed it leaning out. 255 Walbro fixed that.
Supporting Vendor
I use the 255 lph pump with my 383
Great pump, great company to deal with
Once again I playing the Cali smog games will this effect my fuel pressuer if so can I still pass smog with this pump.
I read others have raised there fuel pressure then the car will not pass smog.
Racetronix kit here with the extra wiring kit. Good deal.
Marv, pressure is dictated by your fuel pressure regulator (if aftermarket, it could be adjustable) but no this won't change your fuel pressure.
Marv, the PCM will be closed loop and will adjust the mixture accordingly. Unless you have a modified engine pushing somewhere in the vicinity or north of 500hp, you have no need for the larger pump. They also sell a stock sized pump. Get that and you'll be fine, performance and pressure wise. Perhaps he'll cut you a deal since it's not listed above
Supporting Vendor
St. Jude Donor '10-'11
Im buying fic 24 lb injectors instead of my old *** 22 lb injectors already in it. I think upgrading the fuel pump wont help add power but it looks like it's good quality.....what is the benefit with the harness kit sold separatley? what exactly does that add?
Supporting Vendor
http://www.racetronix.biz/itemdesc.a...WH-007&eq=&Tp=
If you are only running 22-24LB injectors it is unlikely that you require a Walbro 255LPH fuel pump. Unless your fuel pump or injectors are failing there is no point to change either.
We offer a wide range of direct-fit injectors for C4 Corvettes.
http://www.racetronix.biz/items.asp?...atus=0&Tp=&Bc=
Supporting Vendor
- 1986 Original Owner -
I just bought one of the 190s this morning and it's already been shipped! These guys are great.
Racetronix pump and wiring kit keeps the pressure up for my 355 even at 7200rpm...my factory pump passed the FSM checks but pressure would drop like a rock above 5000rpm in 3rd
