L98. Removing injectors from fuel rail
I will post this tip up here as someone may benefit from doing a search on this subject in the future.
I got new Bosch IIIs from FIC. When it came time to pull off the old injectors I was totally stumped. Tried everything except the BFH (Big Freakin Hammer). I finally called FIC and he told me to look at the tang that sticks out from the C clip that holds the injector on. He said to take needle nose pliers and rotate the tang as far as it will go in the other direction. Then firmly wiggle and pull the old injector out. Worked like a charm. Now on with the rest of the job.
/Benny
And, depending on the runners mounted (OEM or aftermarket), it's possible to change out injectors w/o removing the plenum/runners. That is,,,if you leave the clips OFF when reassembled.
Those clips were reportedly used for assembly purpose. The held the injectors in the rails until installed in vehicles.
Injectors won't malfunction or "fall out" if the clips are absent.
Also as a safety tip I found that even though I relieved the pressure in the fuel lines that the intake line weeps a bit and dribbles gasoline back down the outside of the line and onto the floor.
I returned home from work that night to a very strong odor of gasoline.
I had read somewhere on the Corvette troubleshooting web site about how to prevent this same problem when doing a fuel filter change.
They said to remove the rubber bib that surrounds the fuel filler and clamp off the rubber line with vise grips. I did this and the siphoning stopped. Now I feel much safer.
My next step is to remove the intake manifold and put on a used ported one that I bought from a member here. I am also installing some SLP runners and using a die grinder to port match my plenum to the runners.
While all this stuff is off I am putting on a used tach filter, new oil pressure sender, thermostat and EGR valve. Then on to the mixture of used and new performance exhaust parts I have laying around.
I am driving 10 hours each way to Corvettes at Carlisle in about 6 weeks so I sure hope I am doing everything correctly and do not bust off any bolts in the process.
I call this Corvette therapy.
