Exhaust flange vendor?
Is there anyone who sells the flanges used to connect rear Y-pipes to the mid-section?
I'm talking about the oval(ish) flange that has 4 bolt holes on an LT1.
(On an L98, it has two bolt holes...but I need the 4-bolt version.)
I'm not picturing exactly what you want there but I did get flanges from Summit when I built my exhaust.
http://www.summitracing.com/search/D...s/?Ns=Rank|Asc
Looks like they are all three bolt. If you can't find them you may have to fab some, fairly simple part to make.
Interesting....Yep, I have been looking to see if I could find the 4-bolt flange as seen on the 84 Y-pipe above. (Don't need the rest of the "Y" though.)
FWIW: It was part of the 91-96 kit for SideEffects. So, I thought there must be a flange behind the resonator. Guess not. PowerEffects doesn't have them any more. (BTW,,,they said LTx had 4-bolt vs 2-bolt for L98s. Sounds like they remember wrong.)
That flange is probably only available (if at all) from exhaust manufacturers. My exhaust shop didn't know if they could get one.
