Will LT1 Heads Work With Hot Cam ?
No, I have a custom ground camshaft matched to my ported LT1 heads.
The Hot Cam is fairly mild for a DD, especially if it is a M6 car. For an A4 you might need a little higher stall converter.
What kind of H.P. increase you'd guess I'd get with just changing to the Hot Cam?? .I have stock exhaust as well.Just want a little more Umph !
I'll definatly will get a PCM Tune.
Might as well buy a new one. The cam itself is only a coupe hundred bucks. If you already have the springs and rockers. The savings over buying a used one vs. peace of mind of new isn't enough IMHO.
