what is the best brake booster to buy?
So I replaced my old broken brake booster with a new one from autozone...i think it is just a junk rebuilt one because the car doesnt run right with the new booster installed after 2 days of it being installed it started with the problems
any ideas where to get a new not a rebuilt brake booster from that will last and work for more than 2 days?
thanks
thanks
try summit racing - they have an A1-Cardone rebuilt unit for about $160 + core. dont know if its better than the autozone units though. other than that, your best bet would be an AC Delco unit, but the price is somewhere north of $350.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
If you search on this topic you'll find out that you are not alone. Other members bought aftermarket boosters and it/they was/were not working properly.
If I was you I would buy an OEM one
I'd say that Cardone is the same one as Autozone.
thanks
thanks
Corvette Central does sell a metal booster. Don't know if it is new or rebuilt. But something to look at before you spend $400+ for an AC Delco booster. I've heard good things on the metal boosters.
When you say your car doesn't work right. Can you be more specific? Is it brake related, or something engine related? Because if it was engine related, then that would make me think of the check valve as that can cause a vacuum leak. The Cardones do come with a stupid 3 port check valve where two of the ports have to be plugged.
I have read of people having problems with there boosters after installing headers , because of the heat put out by the headers it has been suggesed by a few people to install the metal boosters in there place.If you have headers I wouldn't install a plastic booster...WW
I installed a metal booster from Napa a few years ago. It was cheap and still works great. The only problem is that it's starting to rust a bit.
I just installed a plastic booster after my header pipes cracked the old one. I made a heat shield out of a few layers of heavy aluminum foil. It is tucked out of sight and it works great! I smoothened it and painted it black so you wouldnt know it waS there unless I told you.
ok so the day i had the booster installed the car ran fine idled like it did before the install etc.
the next day the car would just stall out instantly when i turned the key so after messing around with it i have found out what i need to do for the car to run
the new booster has the stupid 3 port check valve so everymorning i have to pop the hood pull off the hose from the check valve that comes from the intake and leave the 3rd port uncapped
so at this point i have the hose disconnected the top valve capped the 3rd valve uncapped and i start the car like this
after the car is running for a minute i reconnect the hose to the check valve and leave one port uncapped and the 3rd port capped
if i cap all the ports the car will instantly stall out so i have to leave the 3rd port open which in return makes the brakes not to function properly since the 3rd valve is open
when i picked the car up from the install all the ports were closed like they should be and the car ran fine but within a couple days it started running like crap.
Italked to the guy that installed it and he feels that the brake booster is just a crappy rebuild.
I also tried a new original check valve and that also caused the car to stall out instantly
I dont know what to do
any advice would be helpful
Did you buy part #54-71401 from Autozone which is the same Booster manufactured by PBR Girling or ATE that are sold by most Corvette vendors?
If not, I'd return the Booster and buy the correct Booster at NAPA or any of the Corvette Vendors here.
The one at Autozone is a rebuilt Cardone. I've got one for my 89 and it too has a universal 3 port check valve with 2 of the ports capped off.
As the booster they have listed on their site is plastic and is the same pic as the plastic Cardone from Autozone. But maybe they are getting in the metal ones and haven't updated the site.
But I'm not a mechanic and only guessing. But it sounds engine related as it is my understanding that you should be able to plug the booster hose on the engine side, and the car run fine.
What you could try is with the booster hose off the check valve and car running. Stick your finger in the booster hose to block off the air and see if it stalls. I believe it should still run fine with your finger in that hose. If it stalls just by putting your finger in the hose. Maybe you could report that to your mechanic to see what he says.
I just looked again on Napa's site. And they show a plastic booster in the pic. But in the description it says:
"Cast Iron Units Premium Phosphate Coated To Extend On-Car & On-Shelf Life.; 100% OE Quality Seals, Diaphragms & Check Valves Are Installed On Every Unit For OE Performance & Reliability."
Though, I checked with Napa, and it appears that too is a Cardone. Though, it is hard to tell from what it says in their computers, and what they actually get.
