1992 Cooling Fans & AC Compressor not working...correlation?
Old 09-14-2010, 10:58 AM
KCSS
KCSS's Avatar
Default 1992 Cooling Fans & AC Compressor not working...correlation?
I'm calling on the wisdom of the forum. I have a 92' LT1 I purchased the car in the early spring and never noticed it running hot, probably because it was much cooler outside. I don't drive the car that often but have noticed in the summer months it's getting really hot. Coolant temps of 250+!! I took it home and have no cooling fans. When I bought the car I was told that the AC needed a charge but upon further investigation the compressor isn't even trying to kick on. Could these two be related?
I looked at the passenger side door fuse box, but didn't see any fuses for the cooling fans? I'm assuming they are under the hood? Could I be lucky enough that these two are related and just a fuse or relay problem?
I appreciate any help.
Thanks!
Old 09-14-2010, 11:35 AM
twin540
twin540's Avatar
Check the fuse links behind the battery. I had same problem couple months ago.
Old 09-14-2010, 11:39 AM
onedef92
onedef92's Avatar
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The cooling fan relays themselves are on the same side as the A/C compressor. Trying to locate a pic of the engine bay for clarity.
Old 09-15-2010, 12:38 PM
KCSS
KCSS's Avatar
Is there anyway to identify if it is a fuse link or relay without just replacing them to see?
Old 09-15-2010, 03:21 PM
twin540
twin540's Avatar
When fuse links go bad you can visually see them burnt. Check and follow the voltage to the relay.
To 1992 Cooling Fans & AC Compressor not working...correlation?
Quick Reply: 1992 Cooling Fans & AC Compressor not working...correlation?
