1996 F45 shocks
Old 09-15-2010, 06:02 PM
Bulldogger
Bulldogger's Avatar
Default 1996 F45 shocks
Here is my question. In 1996 when the corvette switched from fx-3 to the f45 system, is the shock absorber in the 1996 car the same as 1997 and up model, or is it the same as the 1995 style shock.
The FX-3 is a rebuildable system. The F45 isn't but there is a conversion kit to go from F45 to F55 but it lists 1997 and up corvettes. Will this system work on the 1996 F45 system? or is the 1996 f45 system unique only to that year. Thanks
Old 09-15-2010, 10:56 PM
Aurora40
Aurora40's Avatar
The C5 shocks I've seen look nothing like C4 shocks. I'd be absolutely stunned to find out they are interchangeable. I suspect this is why the kit you are talking about doesn't include the 1996 model year.
The '96 F45 is a one-year system. Fortunately you can replace them with regular C4 shocks.
Old 09-15-2010, 11:37 PM
96GS#007
96GS#007's Avatar
Received 1,739 Likes on 1,047 Posts
'96 F45 is a one off, one year wonder.
Old 09-16-2010, 08:04 AM
bac22
bac22's Avatar
Delco made the shocks in 1996 and it's a one year shock...I just want to thank GM for making a common replacement component that only serviced a single production year !
Old 09-16-2010, 10:55 AM
Bulldogger
Bulldogger's Avatar
Thanks guys that what I thought. Combine that with a changed OBDII system after 97, and the 96 corvette is almost like the bastard child. Thanks GM
Old 09-16-2010, 12:34 PM
onedef92
onedef92's Avatar
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The '92 ECM's are hard to come by, too. Fortunately, there are several companies that rebuild them.
Old 09-16-2010, 08:45 PM
grinditout
grinditout's Avatar
I have an entire, working F45 system available off a 60K car.
Old 09-16-2010, 09:41 PM
96 lt-4
96 lt-4's Avatar
Delphi made the f45 shocks for the 96.They are no longer made or serviced.Last I checked(several years ago)GM no longer had any either.
I used Bilstein shocks and removed the bulb from the info console.
Old 09-16-2010, 11:05 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
fact and discontinued
To 1996 F45 shocks
Quick Reply: 1996 F45 shocks
