I can see why an LT1 doesn't make the same power as an LS1
Its head design.
The LT1 has higher compression than the LS1 and ZO6 LS6. LT1 has 10.4:1 compression, LT4 has 10.8:1 compression. LS1 (most C5s) with 853 heads has 10.1:1 compression and ZO6 243 heads have 10.5:1 compression.
The intake runners on LT1 heads are about 2" x 1". This is puny. The Intake runners are on 853 LS1 heads are abou 4" x 2 inches - huge! The combustion chambers on LT1 heads are smaller. I believe 52cc to LS1 54cc.
The exhaust ports look about the same size on both heads.
What about that 'heavy' metal intake manifold on the LT1? Looks to be about 20 - 35 lbs. It's a dry manifold - isn't it. If dry it could be plastic?
I believe its the intake runner size. LS1 853 heads with less compression make more power than the LS4. The LT1 / LT4 can't breath.
Does anybody make a set of heads with similar size intake runners as the LS1 for LT1. Why doesn't anyone make a plastic intake manifold? When I put an LS6 manifold on my LS1 it probably weighted < 10lbs. Why doesn't FAST make a plastic manifold for LT1 / LT4?
Received 3,043 Likes
St. Jude Donor '05
Probably not enough willing to spend the money on them. Looked into it a few yrs ago and to make them 50 state legal for LTx and L98 the cost was stupid high pretty risky.
LSx heads flow a bunch of air at all lifts totally different design than gen 1 sbc also have a different valve angle. Gen 1 23 deg LSx was 15, 12 something like that? Compression plays a small part but its more the head and tuning capabilities than anything imo. Lotsa LSx experts that may chime in with better info though.
Its the valve angle on the heads and the fact they flow so much more air than a LT1/LT4.
They also got bigger cams than LT motors. Duration wise maybe a little less but much more lift which on higher flowing heads it makes more power.
LT4 vettes can run with LS1 vettes tho. Bolt ons to bolt ons I think the LS1 wins.
AFR makes a 227cc altered valve spacing LT4 type head that will make serious power on the right combination... think 383-396" and higher rpms. Needa well balanced, very lightweight rotating assembly for this however with the long stroke, but a solid roller LT1 using a head like that can rival most similar cubed LSx motors but the LS1 based motors still can get better heads.
I think the biggest amount of work went into the intake port design of the heads. It is night and day difference from the Gen-1 heads, even under a carb manifold they perform well.
The larger ports do make a difference, but the main hp increase is due "cathedral" port design which allows the intake charge to take a straight shot to the valve and combustion chamber.
Stock LS1 and LT4 dyno curves are very similar. Not a lot of difference there.
LT1 and LT4 intakes are dry. I suppose it's possible that you could make one from plastic, but bear in mind that it needs to be able to seal oil within the lifter valley.
Live well,
SJW
Live well,
SJW
Size doesn't matter!!! (I've heard that before!)
cuisinartvette nailed it. The LS heads are 12 degree valve angle design with high ports for a straighter shot into the combustion chamber.
Some race SB1 heads are 18 degree but there's only so far the intake port can get raised to compliment them. You can't even get close to the LS design with them.
The shallow valve angle along with high ports flows way more air than even large SB1 ports can flow.
-- Rick '92 LT1
-- Rick '92 LT1
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
Factor in a superior runner design in the head coupled with the 18* vs. 23* valve angle, and improved runner design in the manifold and you get why the LS1 is more powerful than the LT1. It's just a factor of evolution. The cathedral port itself isn't the main factor, it was more of a by product of the design. The LS7 and LS3/L76 all have rectangular ports like it's Gen II Predecessor though, and they DOMINATE the LS1/6/2 cathedral port design. The simple fact is the valve angle and overall runner design lends itself to a vastly superior flow without a greatly increased volume, promoting higher velocities with an easier entry angle.
The LT4 head stands up initially, but it's 23* design limits it's ability to respond to mods and it's ability to keep up with it's younger brothers.
Fixed.
Live well,
SJW
The intake manifold on the LS1 does a much better job of channelling the air flow and maintaining air velocity to the ports compared to the LTx manifolds. Larger single TB aids in this as well, far less air turbulance.
It also doesn't hurt the LS1 that each spark plug has it's own coil a mere 6" away.
Stock rockers at 1.7:1, and redline at 6800 also gives the LSx a distinct advantage.
St. Jude Donor '05
Just to give an example of the power potential of the LSx check this out.
Started with a 12:1 327 big solid flat tappet, old school iron heads then to 195 AFRs. Heavy car that struggled to get in the 12s I believe and with the 195s dropped some more, cant recall if he hit 11s or not.
Now took a junkyard LSx shortblock had the stock heads ported, 230ish cam/carb and is going 10s with trans slippage.
Hard to do that with a Gen 1 Chevy esp the mph.
If I ever build another mill it will be a LSx its simply easier to make big power thats driveable.
http://www.chevelles.com/forums/showthread.php?t=331501
And keep in mind that anything Gen 1 is all based on the same design from 50+ years ago. You can improve the basic design just-so-much and then after that you have to start making major changes to get muhc more of an improvement. The SBC has always had a problem with the pushrods passing through the port area making that big bulge in the port. The only real way to get around that is a total re-design.
Frankly, I'm amazed at how much power you can make out of a Gen 1 engine nowadays. With the recent (last 15 years or so) computer designed HR cams, heads and intakes, you can now make WAY more power and get better mileage than what we could when my 84 was a new car. That's saying a lot for an engine that had already been around for 30 years 1/4 of a century ago.
The new engines are just a wonder to behold. My best friend Mike has a new Z06. That thing is a total MONSTER when you get on it, yet it idles smooth, has A/C, is totally quiet cruising on the freeway and gets 27mpg. If you'd told me 20 years ago that I could have a 505 hp 427 with manners like that and that kind of mileage, I'd have written you off as being on drugs - now it's a reality. Totally amazing. My 70 Super Bee 440+6 made about 425 hp and got 6 mpg when you drove it "normally" and only once did I get 10 mpg. That car was no where NEAR as quick as most of these new cars and sure wasn't as comfortable and couldn't handle well at all.
Technology marches on..........
Yeah but I would rather have the Superbee
I just remind myself that the cars would never have survived the divorces.............
Here is the only picture I have of it. In the background in my friends 69 Hemi Road Runner and in the driveway is his 500" Hemi Demon drag car - it ran 8.55 @ 155 back in 1985
Ok, so are these worth anything to an LT4 owner, are you going to see a worth while performance increase over a stock ported head.
http://www.trickflow.com/egnsearch.a...8&autoview=sku
St. Jude Donor '05
LT4 head is 195cc If Im not mistaken flow #s arent too far apart on them.
Pro Mechanic
LT4 head vs. box TFS GenX = GenX by a little. Ported, the GenX will murder a ported LT4. Even the original TFS heads (the 195 that are 23* like what I have on my LT1 Trans Am) were superior to the LT4's. The aftermarket doesn't just copy the original design, they make improvements here and there that add up to noticable gains.
