Need pics of L98 spark plug wire looms
Received 3,043 Likes
St. Jude Donor '05
Where they fit onto valve cover bolts, etc.
Stock type only.
Stock type only.
St. Jude Donor '05
Ok you jogged my memory.
The ones on later L98s that attach with the brakcet off the head and the plastic pieces and also earlier ones that attach at valve cover bolts? Been awhile.
Vetteoz , Do you have any more of these stock L98 engine pics you could email me? Thanks! Corvette95@charter.net
Don't know if this helps you, but it shows what they look like and how they are positioned.
Perimeter covers
http://members.shaw.ca/agent86/Spark...g%20Wiring.pdf
Perimeter covers
St. Jude Donor '05
Thanks Dan,
any close ups of the one in the pic where they mount (centerbolt type)
St. Jude Donor '05
The four brackets have 2 ,1/4-20X1/2" bolts each that fasten them to the head (113 heads) or in my case the header (TPIS) flange. The bolt holes are just visible in the head in the pic. Each bracket has two wire separators except for the rear passenger side which has three. The rear passenger side bracket also has a heat shield (that I removed ) for the EGR tube.
The pieces are kind of odd looking, but work quite nicely.
more pics in this thread. #5 spark plug wire is interesting.
http://forums.corvetteforum.com/c4-t...-l98-pics.html
