How do you check fuel pressure while driving?
Old 10-08-2010, 10:43 PM
steverichmond
steverichmond's Avatar
Default How do you check fuel pressure while driving?
***Newbie Alert****
I've seen several suggestions in a number of threads suggesting that the OP check the fuel pressure while driving. This leads me to believe you can get the fuel pressure to display on the dash. If this is the case, I am/was totally unaware of this functionality. Can you display the fuel pressure? If not, Sorry for the stupid newbie question.
Thanks,
Steve
Old 10-08-2010, 10:46 PM
cumbercr
cumbercr's Avatar
Tape a gauge to the windshield.
Old 10-08-2010, 10:51 PM
ex-x-fire
ex-x-fire's Avatar
Get a univesal fuel pressure gauge & tape it to the windshield. I was thinking the other day about why efi vehicles do not have a fuel pressure gauge in the gauge cluster, on some of them the engine wont run if the psi is only 5psi below the spec.
Old 10-08-2010, 11:05 PM
John A. Marker
John A. Marker's Avatar
So, guess what I was doing yesterday and today....
Trying to trace down a lean exhaust code 44 condition. Just switched out fuel pumps.....20 minute job. All right...Chevy finally did something right when they put the fuel pump in the Corvette.
Old 10-08-2010, 11:16 PM
jfb
jfb's Avatar
Picture of a genuine automobile mechanic.
Old 10-09-2010, 01:23 AM
c4sailor
c4sailor's Avatar
I particularly like how he used the wiper instead of more tape!
Old 10-09-2010, 01:26 AM
samsonb
samsonb's Avatar
The bad part is you can barely read the gauge.
Old 10-09-2010, 01:54 AM
legsandvettes
legsandvettes's Avatar
the matching tape is the finishing touch!!!
Old 10-09-2010, 03:30 AM
gmayer5454375
gmayer5454375's Avatar
Good start on tracing the code. I tested my fuel pressure when idling. My mechanic tried chasing it down too and had trouble. He replaced the O2 sensor (a previous owner put an aftermarket one in, so I was happy to go back with AC anyway). Then he was chasing the MAP sensor when I suggested to check the injectors. Found the problem, he put new Delphi injectors in and it runs great. Not sure of your year, but mine is a '90. From your pics it looks like you have a 91 or newer. My guess, if fuel pressure is good, check the injectors.
Old 10-09-2010, 05:36 AM
Midnight 85
Midnight 85's Avatar
Finalist 2020 C4 of the Year - Modified
Check out a company called Prosport, they make gauges and one of them is an electric fuel pressure gauge. A sender mounts on your fuel rail then is wired to the gauge which I put in a pillar pod. I'll get some pics later and post them. The gauge works & looks great.
Old 10-09-2010, 11:37 AM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
To How do you check fuel pressure while driving?
Quick Reply: How do you check fuel pressure while driving?
