Will stock LT1 throttle body work on L98 motor?
it will bolt up it's the same TB housing
you will need a LT1 Throttle cable unless you have a 89 - 92
The IAC is different
The TPS is different
you can swap the IAC & IAC housing
TPS 4 wire vs 3 wire
Depends on the year....as mentioned linkages and be different and some of those LT years have an extra tiny hole in the face throttle body to allow extra air slip past when the blades are shut...not talking about the IAC port. You can tap the extra hole and block it off though.
