How do I disassemble a 1992 ECM?
I tried to disassemble my ECM on my 1992 LT1. It looks like there is a box inside a box that might need to slide out. I didn't want to force anything for fear I might ruin it. I'm hoping somebody has been down this road before.
The reason I need to take it apart is because I have an intermittent problem. My torque converter lock randomly disengages after a few minutes of driving. Diacom shows aberrations of the speed signal generated by the ECM. I replaced the speed sensor and brake switch is good. I connected a switch directly to the 4L60 via ALDL connector to make sure all the components in the trans are good. I suspect there is some corrosion or a loose solder connection that needs to be corrected.
-Remove Memcal
-Remove all screws on case.
-Remove screws on connector housing (Top).
-Slide out circuit board.
-Note there is a rubber seal between the metal case and the connector housing that may stick togather, it just take a little more effort.
Top View
Bottom View
Lower support removed
Top View
Bottom View
Very good!
Yes, the rubber must be holding it. I'll pull a little harder and if need be apply a small amount of heat.
It also looks like I'll need to remove the conformal coating. There are a number of different types of conformal coatings. Do you know what kind of solvent to use?
Also, thank you very much for helping me!
The board in the pic looks a bit messy because it was rebuilt by Cardone and is coated with the varnish coating.
As a profession I'm an electronic technician so a least trying to repair it seems to be the logical thing for me to do. I do know that the large scale integration (big chips) will be impossible for me to troubleshoot or replace so re-soldering will probably be my only recourse. I hate the thought of buying a rebuilt one.
Thanks again for your help and wish me luck!
i want to disassemble the ECU on my 96 C4, only to have the 2 outer cases powder coated. Is this possible/easy? Don't want to break or ruin the ecu in the process.
