sys flashing in dash
Old 11-09-2010, 10:24 PM
sharp90
sharp90's Avatar
Default sys flashing in dash
Recently I had my break booster replaced at a local chain repair shop. I returned to pick up my car, they battery was dead and would not start. I then promtly walked back inside to imform them they need to figure it out, quickly. Found they did not adjust the break light switch at the break peddle. The lights just stayed ON. Ya think you may have noticed that little bright row of lights at the back end of the car....
Anyway, after charging of my battery and driving for nearly 2 weeks, i still have the "sys" light in the dash also my fuel guage shows empty. I have tried the search on here as i do on a regular basis, it is a corvette. I have not found anyone with the same fuel guage issue associated with the sys light. looking forward to any help. thanks in advance.
Old 11-09-2010, 11:13 PM
jeffp1167
jeffp1167's Avatar
If my 90's cluster isnt really tight it will do that
Old 11-10-2010, 08:27 AM
sailorsteve
Support Corvetteforum!
sailorsteve's Avatar
With the "sys" light flashing, there is a code stored in the ccm. That code might be of some help in diagnosis. Look in the forum "search" function for info on reading ccm (not ecm) codes, I believe your year self-diagnoses.
Old 11-10-2010, 07:48 PM
jimmers
jimmers's Avatar
Either that or a weak battery.
Old 11-12-2010, 06:19 PM
sharp90
sharp90's Avatar
i beleive it may be a weak battery as its was drained by the repair shop
Old 11-14-2010, 10:19 PM
primalurges
primalurges's Avatar
I've had my SYS flashing for month but everything works and no codes are stored (96 LT4). I read somewhere that replacing factory stereo will do that. Just in case youve done anything else like changing stereo.
Old 11-14-2010, 11:57 PM
Z-07 freak
Z-07 freak's Avatar
Location: Why are there squished peanut butter cups in my underware?
Fill up the tank with gas. Duh.
Old 11-15-2010, 01:16 AM
Binski
Binski's Avatar
Typically the battery is bad or has a low charge.
Old 11-15-2010, 07:30 PM
sharp90
sharp90's Avatar
If only I could be as savy as you.
Old 11-15-2010, 07:38 PM
sharp90
sharp90's Avatar
found the main problem, battery is less than a year old. when then brake booster was operated on, the pedal switch was imporperly adjusted causing the brake lights to stay on. the ccm code was stored as a weak battery. cleared the code and will now move on with diagnosis of fuel level issues. thank you to all with usefull advise, unlike blondes with large mamories beleiving that they really brains, when infact, they're just a mound of fat with a nipple.
Old 11-16-2010, 01:06 AM
Z-07 freak
Z-07 freak's Avatar
Old 11-16-2010, 08:45 AM
sharp90
sharp90's Avatar
Classy. Thank you for illustrating my point.
Old 11-16-2010, 04:50 PM
Z-07 freak
Z-07 freak's Avatar
You're welcome diamond farter.
Old 11-16-2010, 05:15 PM
sharp90
sharp90's Avatar
not sure what that would be....but, okay.
Old 11-16-2010, 11:47 PM
94vettelover2
94vettelover2's Avatar
Thanks for keeping us informed on what you found as it may help us in the future
Old 11-17-2010, 07:13 AM
sailorsteve
Yet another example of why to do your own repairs.
Old 11-17-2010, 11:34 PM
sharp90
sharp90's Avatar
Agreed. Also, found they had disconnected vacuum lines as well. nice.
To sys flashing in dash
Old 11-18-2010, 07:00 AM
vette079
vette079's Avatar
AHA, they "prepped" your car so you will come in for the "next" repair?
Old 06-29-2014, 04:17 PM
Joe
Joe's Avatar
Default my 90 has a sys flashing on dash
my 90 has sys flashing on dash too . battery was also low , have charged it now how do I clear the ccm code ?
Old 06-29-2014, 05:55 PM
WVZR-1
WVZR-1's Avatar
Received 2,255 Likes on 2,018 Posts
I answered the other thread you tagged on to that was nearly 9 years old, This one is nearly four years and I'd suggest you just start a "NEW THREAD" and mention your problem or challenge. Always state the year - in the other thread I supplied you a link that should be all you need to know about clearing the CCM codes and the explanation of them and how to scan several systems on your car using the DIC. If your car has C68 (auto-air) there are diagnostics that can be done using it also.
If you need to just start a "NEW THREAD"!
Quick Reply: sys flashing in dash
