1987 Corvette Cruise Control - Help!
Old 11-15-2010, 09:45 PM
vetterobert
vetterobert's Avatar
Default 1987 Corvette Cruise Control - Help!
Hi guys,
1987 Corvette, 4 + 3 standard trans, cruise control inop. I have a factory manual with supplements on my Christmas list, but for now all I have are the Haynes and Clymer manuals. They are all but useless for electrical problems. I worked all afternoon trying to trouble shoot my inop cruise control to no avail. I have a long trip coming up and sure would like to make it work.
Does anyone have an applicable wiring diagram for this car/cruise control???
Thanks!
vettebob
Old 11-15-2010, 11:06 PM
AGENT 86
AGENT 86's Avatar
From my 86 FSM, should be the same.
http://members.shaw.ca/dankai/Cruise%20Control%209C.pdf
http://members.shaw.ca/dankai/Cruise%20Control.pdf
Old 11-15-2010, 11:21 PM
kimmer
kimmer's Avatar
C4 of the Year Finalist
Check the switch at the brake pedal, that was my problem.
Old 11-16-2010, 03:41 PM
vetterobert
Default Cruise Control
Wow, what great info!
Thanks a bunch!
vetterobert
Old 11-16-2010, 03:49 PM
3D-Aircrew
Support Corvetteforum!
3D-Aircrew's Avatar
Default Vacuum Line
Originally Posted by vetterobert
Hi guys,
Thanks!
vettebob
There is a cruise control module located above the battery that MUST have a solid vacuum line or else it won't work. Rubber lines located near the battery tend to deteriorate.
Old 11-16-2010, 04:22 PM
glava2876
glava2876's Avatar
Same for mine.
Old 11-16-2010, 04:28 PM
engle1147
engle1147's Avatar
Here is good write up with pics about a problematic cruise control issue related to a failing brake switch.
http://forums.corvetteforum.com/c4-t...-for-94-a.html
Old 11-16-2010, 04:32 PM
Dr.Huxtable
Dr.Huxtable's Avatar
Definitely take a look at the vacuum lines under the module under the hood. Was looking at mine last night and they would like rub away on my finger. Might want to replace anyway
To 1987 Corvette Cruise Control - Help!
Quick Reply: 1987 Corvette Cruise Control - Help!
