Need Help Understanding OBDII info
Old 11-23-2010, 12:49 AM
dogfish246
dogfish246's Avatar
Default Need Help Understanding OBDII info
Ok, I am just wondering how to read this information... I know most of it but have a few questions...
What exactly is the calculated load value?
What is the short term fuel trim and long term fuel trim bank?
What should the ignition timing advanced be at idle, wot, etc?
How do you read the O2 sensor readings and what do they mean? What are the "good" range of values and how can you tell if something is wrong?
I tried to read up on some of this stuff but I think it would be good to get some feedback and info from you guys!
Thanks guys!
Old 11-23-2010, 07:43 AM
vetteoz
vetteoz's Avatar
http://www.cartechbooks.com/vstore/s...=3657&CATID=21
What ever is programmed in to the the PCM.Need tuning software to read program
If working correctly and in CL then the O2 voltage should rapidly change from hi - lo - hi.
If the reading is static then O2 sensor is not working
Old 11-23-2010, 11:40 AM
dogfish246
dogfish246's Avatar
Thanks for the info! That was a good read! Its nice to know what your looking at and what it means!
To Need Help Understanding OBDII info
Quick Reply: Need Help Understanding OBDII info
