Which Flexplate do I buy?
I'm running a 96 LT4 with a 4L60e Trans. I need to change the flexplate because of damage teeth on the flexplate.
1. Looking for suggestions on which flexplate to buy and any vendors, supported on here.
2. Also do I need 153 or 168 tooth count flexplate? The engine has a mini starter (gear reduction?) which I think is stock for the LT4 and didnt they come with 153 teeth?
Thanks for any response,
Bill
Bill
Any 153 tooth wheel to suit 1 pce RMS crank (ext balance)
Has a weight welded to it ;if not is wrong one ( neutral bal )
One to suit a earlier 2 pce RMS crank will not bolt up as the bolt patterns are different
