Carb swap?
#41
Received 3,043 Likes
St. Jude Donor '05
Id say his car is well sorted out and if Im not mistaken sees street duty too. It takes a lot to pull the wheels like he does give the guy some credit. Gutting a car and weight removal will not pull them up sorry.
By the way what are you running tell us all about it.
#43
#44
Just looking for all the info I can get. I didnt know you couldnt do that...
I guess I'll check with 96white next time and make sure its OK.
#47
come on man!
why would I wanna race? Your car has a bent frame
(from doing those wheelie's) and now you 84 is worthless
im surprised you even pass tech inspection with that bent frame
it probally doesn't even have a title.
Hey look at me, " i have a Ford 9 inch with no interior"
you can store your y-pipe in the back (where the carpet) used to be.
if i pull out my interior--my car will do a wheelie 2.
anybody can do a wheelie with a ford 9 inch and the interior gutted.
can you say " bent, worthless, totaled racecar--with a motor that needs to be freshed up, alittle"
just like a red neck " wanna race"
its going to take a whole lot more than THAT car to impress me
junk
wanna race
i love those big 15 inch tires with the ford bolt pattern
junk
wanna race
#48
If its any consolation 383 Vette, I think you did a nice job on the car. I just sold my 82 Z28, 468 BBC, 350 turbo, 4500 stall, 4.56s with a Moser/Ford rear. 10:80 in the 1/4. I know what kinda work goes into building a nice car and can see the fruits of your efforts.
#49
383 nice ride. I am impressed with the way it launches, amazing! You obviously have your stuff together. I was thinking, we should make a new rule for the board; It should be mandatory that all posters are a minimum of 12 years old, and act like it. This should allow yourself and the other adults to carry on a conversation with out a bug pestilence.
#54
Hey, I carbed my car for a few years.
#56
Im considering a tpi to carb swap. Ive saw a few threads about it. What Id like to know is what did you guys do for the throttle cable. Can I use the stock one? Also, with the high pressure fuel pump, do you just regulate it down to 6 psi or so, or do I have to swap it out too. As for the distributor, is it as easy as swapping to an msd or older hei ?
Any help would be appreciated.
In case you want to know, Im not ready to toss the tpi just yet, just weighing out the costs of fixing, tuning the tpi, vs the carb swap, in which I likely have everything to do in the shop here.
#59
Hi guys Have you seen the electric choke replacements for Holley carbs that gives you Throttle position sensor info to your tranny so you can use newer 4L60e electronic transmissions with a carb. It's apx. 100.00 from summit,much cheaper than those stand alone shift computers are. anyone used one ?
#60
Last moth I did this swap. It was 1990 L98. here is my parts list (summit part#s):
intake: EDL-2101
distributor: MSD-8360
Carb: HLY-0-81670
Coil: MSD-8207
Fuel pressure reg: QFT-30-900
I reused the OEM fuel pump, that's why I used a fuel pressure regulator with return line. My digital display is still working, telling me fuel level.
Remember to buy all gaskets you will need.
Also you will need a fan control to operate the radiator fan (or turn it on direct from switch).
If you will remove all wire harness, please take this advice first: find a signal for ignition coil; be sure not to cut any starter motor signal, find a signal for fuel pump. If you follow this advice you will have: gas, spark and cranking.
find some gauges for oil pressure, water temp, rpm.
been there done that, my Vette is running and pulling strong.
hope this help
PD: I have a TPIS BIG MOUTH, ECM, THROTTLE BODY, SUPER RAM, FUEL RAILS....FOR SALE
intake: EDL-2101
Carb: HLY-0-81670
Coil: MSD-8207
hope this help
