1989 radio
1989 radio
I want to replace the aftermarket radio in my 89 with the original Bose am/fm/cass,but having a hard time finding one. Any suggestions where to find one, also what other year would fit I wouldn't mind one with a CD
Over the years I have found several on e-bay and several on this site. Just keep your eyes open and one will pop up. Even if they are broken or have some problem, there are repairs available with warranties. Here's one I found on e-bay within a 2 minute search:
http://cgi.ebay.com/ebaymotors/1984-...fAudioQ5fVideo
8Valve
Location: Charlotte NC, behind someone going 10 under the speed limit
1 Post
You need a 94-96 Camaro Bose Cd player, I put one in my 88, one of the best things I've done. This is actually my dash. Don't get one from a 93 Camaro though, they had yellow script and the radios were gray not black.
http://forums.corvetteforum.com/c4-t...lay-color.html
8Valve
8Valve
Platinum Supporting Vendor
This is the best option. This is what I have installed on both of my 86's and my Dad's 85. They came out of a 94 Camaro, you have to use the one that match's yours for Bose or no Bose. You can get the wire adapter and antenna coax adapter and any radio supply shop and it is bolt in for the most part. You will have to trim the speaker and fade ***** a little so they don't hit the dash, but it is easy.
That Camaro stuff is an awesome option :-) Right now I'm looking for a radio which will fit the '85 Vette and this is just perfect.
Is that 94-96 radio /w CD available as a non-Bose unit for use with passive 4-Ohm speakers?
